leonucadomi Posted July 24, 2024 Posted July 24, 2024 I would like to know if this is possible and how? I appreciate any comments Quote
SLW210 Posted July 24, 2024 Posted July 24, 2024 Try DwgSearch | AutoCAD | Autodesk App Store 1 Quote
wkplan Posted July 25, 2024 Posted July 25, 2024 Use ODBX, open your dwgs one by one, save results in a list and close searched dgws. Store the results in al list, note name and path. No need for a third-party-tool. Quote
Steven P Posted July 25, 2024 Posted July 25, 2024 2 minutes ago, wkplan said: Use ODBX, open your dwgs one by one, save results in a list and close searched dgws. Store the results in al list, note name and path. No need for a third-party-tool. I reckon most LISPs and automation could be seen as a third party tool.... Quote
SLW210 Posted July 25, 2024 Posted July 25, 2024 Isn't Object DBX a "third party tool"? Plus, you actually didn't detail how to do this method. 1 Quote
Steven P Posted July 25, 2024 Posted July 25, 2024 Yes it is possible as SLW210 but also via LISPs For LISP you'll want to use a batch LISP routine - something like ScriptPro or Lee Macs Script writer to assess each drawing. These will run a LISP to search text strings, so now all you need is that.... If you are using a script you want minimum user interface, anything without a dialogue box, I think this is the basis of what I use: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883 (I refer to it in my LISP find and replace). Modified to record what it finds into a text file. Is it normal text you are searching for? If the text will be for example in a title block, again Lee Mac has a solution with his MacAtt tools, https://lee-mac.com/macatt.html Quote
wkplan Posted July 25, 2024 Posted July 25, 2024 (edited) 6 hours ago, SLW210 said: Isn't Object DBX a "third party tool"? - ODBX is provived by autodesk Plus, you actually didn't detail how to do this method. - search this forum, there are plenty of examples Edited July 25, 2024 by wkplan Quote
leonucadomi Posted July 25, 2024 Author Posted July 25, 2024 18 hours ago, SLW210 said: Try DwgSearch | AutoCAD | Autodesk App Store I use the 2013 version of autocad and I think it is not compatible Quote
leonucadomi Posted July 25, 2024 Author Posted July 25, 2024 what I want is not to replace texts. I am looking to open several dwg. then search for a text string in the open dwg. I would like the tool to tell me in which dwg the text I am looking for is in. try to install DwgSearch | AutoCAD | Autodesk App Store I use the 2013 version Autocad and I couldn't install Quote
leonucadomi Posted July 25, 2024 Author Posted July 25, 2024 an apology, I already saw that what I need is done Batch Find & Replace Text by Master LEE thanks Quote
