pyou Posted July 21 Posted July 21 Hi Could someone help me to tweak this lisp code so text appear outside the polyline and become readable, please? Thank you! (defun c:TextPline (/ obj vert lay du interval total-length current-dist txt pt ang) (setq du (getstring t "Text above the line: ") interval (getdist "Specify the interval between text placements: ")) ;; Select polyline and get its layer (setq obj (car (entsel "\nSelect polyline to lock active layer >"))) (setq lay (cdr (assoc 8 (entget obj)))) ;; Ensure the selected object is a polyline (if (and obj (= (cdr (assoc 0 (entget obj))) "LWPOLYLINE")) (progn ;; Get total length of the polyline (setq total-length (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj)) current-dist 0) ;; Set the text to display (setq txt du) ;; Place text at specified intervals (while (< current-dist total-length) (setq pt (vlax-curve-getPointAtDist obj current-dist) ang (angle (vlax-curve-getPointAtDist obj current-dist) (vlax-curve-getPointAtDist obj (+ current-dist 1)))) ;; Adjust angle if necessary (if (or (> ang (* pi 1.5)) (< ang (* pi 0.5))) (setq ang (+ ang pi))) ;; Calculate the point above the polyline for text placement (setq pt (polar pt (+ ang (/ pi 2)) 0.4)) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 1 txt) (cons 7 "Arial") (cons 8 lay) (cons 10 pt) (cons 40 0.4) (cons 50 ang) (cons 62 256) (cons 71 5) (cons 72 5) (cons 44 1.3))) ;; Increment the distance (setq current-dist (+ current-dist interval))))) (princ)) Quote
BIGAL Posted July 21 Posted July 21 What your missing maybe, "is pline CW or CCW, can reverse pline then text will always go out. (defun Chkcwccw (ent / obj obj2 area1 area2) (setq ent (entsel "\nPick closed pline ")) (setq obj (vlax-ename->vla-object ent)) (setq area1 (vlax-get obj 'Area)) (vla-offset obj 10) (setq obj2 (vlax-ename->vla-object (entlast))) (setq area2 (vlax-get obj2 'Area)) (vla-delete obj2) (if (> area1 area2) (command "reverse" ent "") ; (command "pedit" ent "R" "") ; Bricscad has no reverse ) (setq ent (entsel "\nPick closed pline ")) (Chkcwccw ent) Thanks to Lee-mac for readable. ;; Make Readable - Lee Mac ;; Returns a given angle corrected for text readability (defun lm:makereadable (a) ((lambda (a) (if (and (< (* pi 0.5) a) (<= a (* pi 1.5))) (+ a pi) a ) ) (rem (+ a pi pi) (+ pi pi)) ) ) 1 Quote
