BIGAL Posted August 3 Share Posted August 3 T just is needed for my bricscad, change back to text justify for acad. Typed on phone auto correct makes life hard Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 6 Share Posted August 6 I have updated the code now works out the hor or ver it uses a 20 degree check, a bit rough but seems to work. One less user input. ; https://www.cadtutor.net/forum/topic/88262-mtext-align-and-mtext-width-0/ ; simple align text to line : By AlanH July 2024 ;;; Justification Macros ;;; ;;; https://www.cadtutor.net/forum/topic/35569-text-justification-lisp/?do=findComment&comment=289008 ;;; ;;; BY alanjt (a.k.a. Alan J. Thompson) ;;; ;;; Customized By SLW210 ;;; (defun c:alt1 ( / _justifyIt horver ent fo k ans but ss oldsnap pt obj ptn fname) (defun dtr (a) (* pi (/ a 180.0)) ) (defun _justifyIt (justify title / ) (princ (strcat "\nSelect *Text to " title " justify: ")) (if (setq ss (ssget '((0 . "ATTDEF,MTEXT,TEXT")))) (command "_.TJUST" ss "" justify) ) (princ) ) (defun horver ( / ) (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (if (= ahdef nil)(setq ahdef 1)) (setq ans (ah:butts ahdef "h" '("Horizontal or vertical " "Hor " "Ver"))) ; ans holds the button picked value (setq ahdef but) ) (while (setq ent (car (entsel "\nPick single text for alignment Enter to exit "))) (setq pt (cdr (assoc 10 (entget ent)))) (setq X (car pt) Y (cadr pt)) (if (= fname nil) (progn (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) (write-line "AHtxtpos : dialog {" fo) (write-line " label =\"Please Choose \" ;" fo) (write-line " : column {" fo) (write-line " : boxed_radio_row {" fo) (write-line " width = 24 ;" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb1\";" fo) (write-line "label = \"Top L\";" fo) (write-line " }" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb2\";" fo) (write-line "label = \"Top Mid\";" fo) (write-line " }" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb3\";" fo) (write-line "label = \"Top R\";" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line " : boxed_radio_row {" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb4\";" fo) (write-line "label = \"Mid L\";" fo) (write-line " }" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb5\";" fo) (write-line "label = \"Center\";" fo) (write-line " }" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb6\";" fo) (write-line "label = \"Mid R\";" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line " : boxed_radio_row {" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb7\";" fo) (write-line "label = \"Bot L \";" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb8\";" fo) (write-line "label = \"Bot mid\";" fo) (write-line " }" fo) (write-line " : radio_button {" fo) (write-line "key = \"Rb9\";" fo) (write-line "label = \"Bot R\";" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line " ok_cancel;" fo) (write-line " }" fo) (write-line " }" fo) (close fo) ) ) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "AHtxtpos" dcl_id) ) (exit) ) (set_tile "Rb1" "1") (setq j 1) (repeat 9 (setq k (strcat "Rb" (rtos j 2 0))) (action_tile k (strcat "(setq but " (rtos j 2 0) ")" "(done_dialog)")) (setq j (+ j 1)) ) (action_tile "accept" "(done_dialog)") (start_dialog) (unload_dialog dcl_id) (cond ((= but 1)(_justifyIt "_TL" "Top Left")) ((= but 2)(_justifyIt "_TC" "Top Center")) ((= but 3)(_justifyIt "_TR" "Top Right")) ((= but 4)(_justifyIt "_ML" "Middle Left")) ((= but 5)(_justifyIt "_MC" "Middle Center")) ((= but 6)(_justifyIt "_MR" "Middle Right")) ((= but 7)(_justifyIt "_BL" "Bottom Left")) ((= but 8)(_justifyIt "_BC" "Bottom Center")) ((= but 9)(_justifyIt "_BR" "Bottom Right")) ) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (if (= ss nil) (progn (alert "You have not selected anything will now exit")(exit)) ) (setq obj (vlax-ename->vla-object (ssname ss 0))) (setq pt1 (vlax-get obj 'insertionpoint)) (setq obj (vlax-ename->vla-object (ssname ss 1))) (setq pt2 (vlax-get obj 'insertionpoint)) (setq ang (abs (angle pt1 pt2))) (if (> ang pi)(setq ang (- ang pi))) ; angle check is 20 degrees (dtr 20) (cond ((and (> ang (- (/ pi 2)(dtr 20))) (< ang (+ (/ pi 2)(dtr 20))))(setq dir "Ver")) ((and (> ang (- (* pi 1.5)(dtr 20))) (< ang (+ (* pi 1.5)(dtr 20))))(setq dir "Ver")) ((and (> ang (- (* 2 pi) (dtr 20))) (< ang (dtr 20)))(setq dir "Hor")) ((and (> ang (- pi (dtr 20))) (< ang (+ pi (dtr 20))))(setq dir "Hor")) ((horver)) ) (repeat (setq k (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq k (- k 1))))) (setq ptn (vlax-get obj 'Insertionpoint)) (if (= dir "Hor") (setq Ptn (list (car ptn) Y )) (setq Ptn (list X (cadr ptn))) ) (vlax-put obj 'insertionpoint ptn) ) ; repeat (setq x nil y nil) ) ; while (vl-file-delete fname) (setvar 'osmode oldsnap) (princ) ) (C:alt1) Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 6 Author Share Posted August 6 I am getting Quote Enter a justification option [Left/Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR] <MC>: _TC Command: ; error: AutoCAD.Application: Incorrect number of elements in SafeArray Busy this morning, I'll see if I can get to it later, I changed the TJUST to JustifyText. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 6 Share Posted August 6 (edited) I copied the code from here and ran it, it worked fine multiple times, I am using Bricscad. Just pick 1 text as ver or hor matching position, then justification, then do a normal window select of text. Enter all done. (command "_.justifytext" ss "" justify) Testing on your sample dwg. You can send me a PM with a new dwg if you want to test. Edited August 6 by BIGAL Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 7 Author Share Posted August 7 I'll try to work it out. Thanks for all the work you put in. Quote Link to comment Share on other sites More sharing options...
