How to cleanly load a function in the cmd echo?
Hiya o/
Just wondering how to make it so that when you load a lisp file into CAD, that it spits out the function's name & not some other sub-function within the lisp file (i.e. if there's 2 'defun's, it usually echos the last defun)
What I've been doing is ordering the defuns so the main function appears last, but that feels wrong/messy.
Thank you!
It seems to simply return nothing when loading, and if I add a string it'll output twice, like this:
(princ "Function loaded.")
: Function loaded."Function loaded."
I assume because it's running the princ as well as outputting the return value?
You could try to define the second function *inside* the first function. Something like:
(defun c:function1()
  (defun function2(position)
    (entmake (list
	       '(0 . "POINT")
	       (cons 10 position))
  (setq ang 0.0 ang1 0.1)
  (repeat 1000
    (setq x (sin (* 5.0 ang))
	  y (cos (* 7.0 ang))
	  z (* (cos ang) (sin ang))
	  ang (+ ang ang1)
    (function2 (list x y z))
If you load this, AutoCAD will report only "function1 loaded".
Does this help you?
  On 7/18/2024 at 8:04 AM, cagorskij said:
Thank you!
Expand
(defun c:foo ( / )
  (princ)  ;<- this one
(defun subfunc1 ( / )
(defun subfunc2 ( / )
(princ "\n function FOO loaded.")
like this
Edited by exceed
Expand
In some languages you have to do it that way. If the subfunctions haven't loaded, you can't call them.
