exceed Posted July 17 Share Posted July 17 in help page, PDSIZE is 0 = Creates a point at 5 percent of the drawing area height >0 = Specifies an absolute size <0 = Specifies a percentage of the viewport size it said affect by height (0) and size (<0), so I tried drawing it upward and long then set 0, but I couldn't see the difference with -5. is it same? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 17 Share Posted July 17 Hard to tell what the issue might be. PDSIZE affects AutoCAD points, so if you're using a different type, it may not be affected. Also check the point type with PTYPE (which lets you adjust the size as well). Maybe change the point type to see if that has any effect; if not, you're dealing with something else. When I drew an AutoCAD point and adjusted the PDSIZE variable, it did what it should have. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 18 Share Posted July 18 The other variable PDMODE is the type. https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-82F9BB52-D026-4D6A-ABA6-BF29641F459B Quote Link to comment Share on other sites More sharing options...
