PeteUK Posted November 13, 2007 Posted November 13, 2007 Does anyone know how to turn the item highlight off on AutoCAD 2008? i.e. when you hover your crosshair above a line/item it highlights it. Previous editions did not do this (to my knowledge) and its quite distracting! Cheers for any help! Quote
Geoffers Posted November 13, 2007 Posted November 13, 2007 options selection ... visual effects settings...? Quote
GE13579 Posted November 13, 2007 Posted November 13, 2007 In 2006 it's ASSIST- OPTIONS- SELECTION- then in the selection preview box there are two check boxes... not sure if it's the same in 2008 or not? Quote
riga Posted November 13, 2007 Posted November 13, 2007 In 2006 it's ASSIST- OPTIONS- SELECTION- then in the selection preview box there are two check boxes... not sure if it's the same in 2008 or not? Probably a difference between Mechanical and vanilla Autocad Quote
PeteUK Posted November 13, 2007 Author Posted November 13, 2007 In 2006 it's ASSIST- OPTIONS- SELECTION- then in the selection preview box there are two check boxes... not sure if it's the same in 2008 or not? Yep, got it thanks. Sorry, could have found it myself, but had a very long day yesterday and feeling a little lazy! Quote
GE13579 Posted November 13, 2007 Posted November 13, 2007 Probably a difference between Mechanical and vanilla Autocad Yep you're right Riga- it's TOOLS instead of ASSIST in Vanilla... just checked, the rest is the same though... Also sorry Geoffers I didn't notice you'd already put down pretty much the same thing Quote
Geoffers Posted November 13, 2007 Posted November 13, 2007 Yep you're right Riga- it's TOOLS instead of ASSIST in Vanilla... just checked, the rest is the same though... Also sorry Geoffers I didn't notice you'd already put down pretty much the same thing No problem, Quote
PeteUK Posted August 5, 2009 Author Posted August 5, 2009 I've just got 2009 version and cant find this again! Anyone shed any light? I'm not liking this new menu system! Quote
GE13579 Posted August 5, 2009 Posted August 5, 2009 Easiest is to type OP or OPTIONS then go to the Selection tab... Quote
