GLAVCVS Posted July 11, 2024 Posted July 11, 2024 Hello everyone. I found a topic from 2021 in this forum about how to emulate the 'dos_splash' function from lisp. That conversation ended without a solution. So recently I decided to write something to solve this and share it on this forum. But I run into the problem that recent versions of autocad do not show changes to the graphic objects in the drawing until the code finishes executing. This is a problem if the goal is for those graphical changes to be seen during execution. Of course: I have made use of 'vla-regen' and 'redraw'. The code works fine in AutoCAD 2002 but not in 2015 or 2021. Any ideas? Quote
GLAVCVS Posted July 11, 2024 Author Posted July 11, 2024 I think I just figured it out I have incorporated a call to 'vlax-release-object' to update the 'ACAD_IMAGE_DICT' dictionary, after modifying it. I will post the code on the 'Topic' 'Splash screen' Greetings Quote
