Dear All,
i need insert title block in to my drawings.I'm using acad 2009.Guys who are working with me using acad 2000 to insert title block becouse that lisp is set on that version. It is not set on acad 2009.I do not like copy tblocks from another drawings and paste into egst.drawing. If anyone can help please ?
Thanks a lot
What makes this need a LISP routine? Why can't you just use "insert" and insert the titleblock manually?
As a first thanks for reply.I can do that and that is very simle but i need than to resize every time block for what i need. I'm new in acad and somebody set that lisp routine long time ago.They have had set everything in block.Well they type title and thay got title block on screen.Even size of title block is depend how much they stretch cross window.I heard that could be set values in multiple drawings like who print job ,time, date etc but that would be another question after i got block.I seen guy who does in acad 2009 but he dont wanna say secret.I guess i find what is needed but no success.I got header but cant get block.
Thanks again on help
Why not setup a template which contains you're title block?
Are you working in PaperSpace or ModelSpace when inserting your Border?
Normally, I would have a set of borders of standard sizes and insert these into a layout, keeping the border at 1:1 scale. Then I would create a viewport inside the border and scale the viewport to suit the objects that I am drawing.
I suppose you could create a template with your border already in one of the layouts, then there would be no need to insert anything - much faster than any LISP routine I know of... :P :P
I'm working in modelspace.Lisp routine is set,bu tido not know how to set whatever need to be set to get titleblock on command title.:(
