mhy3sx Posted July 7 Posted July 7 Hi this is a part of a big lisp code. I use a dcl file to manage 3 options. I try to update the code and 2 more options .I f the five option are in the same boxed_radio_column all work fine, but I want to divide to two boxed_radio_column. In the code bellow I use the same { key=\042key\042 I know that there is the error , but i try to change it but option work in the code. Can anyone help me to fix the code? (defun *error* (msg) (if (and (= 'int (type dch)) (< 0 dch)) (unload_dialog dch) ) (if (= 'file (type des)) (close des) ) (if (and (= 'str (type dcl)) (findfile dcl)) (vl-file-delete dcl) ) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) ) (princ (strcat "\nError: " msg)) ) (princ) ) (setvar "OSMODE" 13) (cond ((not (setq dcl (vl-filename-mktemp nil nil ".dcl") des (open dcl "w") ) ) (princ "\nUnable to open DCL for writing.") ) ((progn (foreach str '( "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}" "" "dgmsynt : dialog { spacer; key = \"dcl\";" " : boxed_radio_column { key=\042key\042; label = \"TITLE1\"; height = 1.0;" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button01\"; label = \"1. OPTION1\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button02\"; label = \"2. OPTION2\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button03\"; label = \"3. OPTION3\";" " }" " }" " : boxed_radio_column { key=\042key\042; label = \"TITLE2\"; height = 1.0;" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button01\"; label = \"1. OPTION4\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button02\"; label = \"2. OPTION5\";" " }" " }" " ok_only;" "}" ) (write-line str des) ) (setq des (close des) dch (load_dialog dcl) ) (<= dch 0) ) (princ "\nUnable to load DCL file.") ) ((not (new_dialog "dgmsynt" dch)) (princ "\nUnable to display 'dgmsynt' dialog.") ) (t (set_tile "dcl" "LEABEL") (action_tile "key" "(setq sng $value)") (action_tile "OK" "(done_dialog 1)") (start_dialog) ;; Main ----- (cond ((eq sng "radio_button01") (_Option1)) ((eq sng "radio_button02") (_Option2)) ((eq sng "radio_button03") (_Option3)) ((eq sng "radio_button04") (_Option4)) ((eq sng "radio_button05") (_Option5)) ) ) ) (*error* nil) Thanks Quote
rlx Posted July 7 Posted July 7 (edited) a radio row or column doesn't have a key (nor does it need a height). Also a new radio column doesn't mean you can start recycling key names. I understand you want to save the planet by recycling but my advise would be to recycle your mother-in-law or something / somebody (foreach str '( "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}" "" "dgmsynt : dialog { spacer; key = \"dcl\";" " : boxed_radio_column {label = \"TITLE1\";" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button01\"; label = \"1. OPTION1\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button02\"; label = \"2. OPTION2\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button03\"; label = \"3. OPTION3\";" " }" " }" " : boxed_radio_column {label = \"TITLE2\";" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button04\"; label = \"1. OPTION4\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button05\"; label = \"2. OPTION5\";" " }" " }" " ok_only;" "}" ) (write-line str des) ) Edited July 7 by rlx 1 Quote
mhy3sx Posted July 7 Author Posted July 7 Hi rlx. I already did this change but every change I do the option1,2,3,4,5 dont work. When I put all in one column then everything work fine. Can any one tell me why? (cond ((eq sng "radio_button01") (_Option1)) ((eq sng "radio_button02") (_Option2)) ((eq sng "radio_button03") (_Option3)) ((eq sng "radio_button04") (_Option4)) ((eq sng "radio_button05") (_Option5)) ) Thanks Quote
rlx Posted July 7 Posted July 7 (defun c:t1 ( / dch dcl msg des drv) (defun *error* (msg) (if (and (= 'int (type dch)) (< 0 dch))(unload_dialog dch)) (if (= 'file (type des))(close des)) (if (and (= 'str (type dcl)) (findfile dcl))(vl-file-delete dcl)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg))) (princ) ) (setvar "OSMODE" 13) (if (not (and (setq dcl (vl-filename-mktemp nil nil ".dcl"))(setq des (open dcl "w")))) (princ "\nUnable to open DCL for writing.") (foreach str '("ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}" "" "dgmsynt : dialog { spacer; key = \"dcl\";" " : boxed_radio_column {label = \"TITLE1\";" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button01\"; label = \"1. OPTION1\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button02\"; label = \"2. OPTION2\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button03\"; label = \"3. OPTION3\";" " }" " }" " : boxed_radio_column {label = \"TITLE2\";" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button04\"; label = \"1. OPTION4\";" " }" " : radio_button { height = 1.0; width = 25; is_tab_stop = true;" " key = \"radio_button05\"; label = \"2. OPTION5\";" " }" " }" " ok_cancel;" "}" ) (write-line str des) ) ;;; end foreach ) ;;; end if (if des (progn (close des)(gc))) (if (and (setq dch (load_dialog dcl)) (new_dialog "dgmsynt" dch)) (progn (action_tile "radio_button01" "(setq sng 1)") (action_tile "radio_button02" "(setq sng 2)") (action_tile "radio_button03" "(setq sng 3)") (action_tile "radio_button04" "(setq sng 4)") (action_tile "radio_button05" "(setq sng 5)") (action_tile "accept" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") ;;; dialog return value (setq drv (start_dialog)) ;;; once loaded , get rid of temp dcl file (if (and dcl (findfile dcl))(vl-file-delete (findfile dcl))) (cond ((= drv 0)) ((= drv 1) (cond ((= sng 1)(_Option1)) ((= sng 2)(_Option2)) ((= sng 3)(_Option3)) ((= sng 4)(_Option4)) ((= sng 5)(_Option5)) ) ) ) ) ) (princ) ) Quote
BIGAL Posted July 8 Posted July 8 If the idea is 2 radio button answers need 2nd button to be say (action_tile "radio_button04" "(setq sng2 4)") as picking 1st button in boxed will be overwritten when selecting second button. This is my attempt at 2 radio button columns. Returns ah:col1 & ah:col2 etc indicating which button is selected. It is a library function use in any code, rather than hard code a lisp. Multi radio buttons 2col.lsp Quote
