stuarth Posted March 20, 2009 Share Posted March 20, 2009 Hi people I have to quote a build It is a cat sailing boat, I THINK it was drawn in Auto something or other as the surfaces were poly meshes, and could not develope the designer sent the files as iges, , I open in r4, and send as iges to maxsurf, but only parts come through many of the surfaces are compound, some heavily so, , maxsurf workshop would do the job IF I could get em into it Anybody have autoship could read the meshes? or help in anyway at all, ia m a builder not a real cad expert at all thanks here is the deck as iges Quote Link to comment Share on other sites More sharing options...
stuarth Posted March 20, 2009 Author Share Posted March 20, 2009 darn file iges cant be uploaded Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 20, 2009 Share Posted March 20, 2009 The forum allows .zip files. You could compress(zip) the iges file, then upload. Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 20, 2009 Share Posted March 20, 2009 Or, for that matter, if the iges file is fairly small, the .igs extension could just be changed to .txt, then uploaded. The max size for a txt file is only 20kb though. Quote Link to comment Share on other sites More sharing options...
stuarth Posted March 20, 2009 Author Share Posted March 20, 2009 Or, for that matter, if the iges file is fairly small, the .igs extension could just be changed to .txt, then uploaded. The max size for a txt file is only 20kb though. thank you muchely:) does this work I have dfx file, not much use to me though cat deck 3.zip Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 21, 2009 Share Posted March 21, 2009 Rhino has a mutitude of iges export option - one is MaxSurf specific. See if the attached does any better job at getting into MaxSurf MSDeck.zip Quote Link to comment Share on other sites More sharing options...
stuarth Posted March 21, 2009 Author Share Posted March 21, 2009 nope did not help, when viewing maxsuf only part of surface is there i have oriinal dfx files which has the surfaces as polygon meshes, I gues I must find someone with Auto ship, but thanks anyways rgds Quote Link to comment Share on other sites More sharing options...
Chris77 Posted March 22, 2009 Share Posted March 22, 2009 i opened it and saved it see attached ms.zip Quote Link to comment Share on other sites More sharing options...
