I am trying to create a viewport module that I can place on sheets. It simply needs to be a square that goes around the detail. Eventually, the sheet will be a grid of these squares with details inside of them.
How do I create a family for this so that I can parametrically change the size of the box each time I place it on a sheet? For instance if the box needs to be 3" x 3", I can create parameters where 1 unit is 1" and by specifying 3 in the element properties dialog boz, it will make that instance of the family 3in wide
