patjeacad Posted July 2 Share Posted July 2 (Defun C:DOORSNEDE0 () (command "-hatch" "Properties" "ANSI31" 0.25 0 "CO" 5 "" "" )) first i do some settings before i use the command hatch. In the command hatch i use pick internal point, i can pick mutiple points. It wil become one hatch. When i use hatch at a lisp file only one time i can use a pick internal point. so i draw more hatches and they are not one hatch. I saw many hatch files with creating a list of point and working with "while". Many don't work or i can not make them usable for me. Can someone put me in the right direction to solve this problem? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 3 Share Posted July 3 My Bricscad does not have "CO" as option ? (Defun C:DOORSNEDE0 ( / pts) (setq pts '()) (while (setq pt (getpoint "\nPick hatch points Enter to exit ")) (setq pts (cons pt pts)) ) (command "-hatch" "Properties" "ANSI31" 0.25 0 pts "") (princ) ) Quote Link to comment Share on other sites More sharing options...
exceed Posted July 3 Share Posted July 3 option "CO" is for set hatch Color. and 5 is in ACI color index. ANSI31 need background color also so you have to change like this, "." means no background color. (command "-hatch" "Properties" "ANSI31" 0.25 0 "CO" 5 "." "" "" ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 3 Share Posted July 3 Understand but my V20 Bricscad does not support "CO". 1 Quote Link to comment Share on other sites More sharing options...
