Sharper Posted July 1, 2024 Posted July 1, 2024 Hello lisp guru's I'm a bit stuck, well to be blunt i haven't even starting writing any code yet, i know the issue i'm going to come up against so i'm trying to problem solve before even getting into it. I want to get some data from a string, and in my mind i'm thinking how would i even start with cadr etc in this scenario, well here's where i'm stumped. The string doesn't have spaces, its continuous, and where a space would normally be it uses a | character for separation. Well i've no idea how i get some data from within this kind of string, with | as the separation character. Here's a rough example Lets say the string is this (and bear in mind these bits of data between the | do vary): "-1|NCC|2.54|30|0|Auto|0|1|0|2|0|0|2|0|False|0|0" (or another to show how it can vary "1|CCR|2.0|37.5|0|User|2|0|0|25|0|0|0|0|True|0|0)" The string is always divided into this many sections (17), the data between can vary but I only ever want to to retrieve the 3rd section of data, in this case the "2.54" and add it to a variable, still as a string, no need to change it to a real for my needs. Could someone point me in the right direction? Quote
rlx Posted July 1, 2024 Posted July 1, 2024 like this? ; (SplitStr "a,b" ",") -> ("a" "b") (defun SplitStr (s d / p) (if (setq p (vl-string-search d s))(cons (substr s 1 p)(SplitStr (substr s (+ p 1 (strlen d))) d))(list s))) (nth 2 (splitstr "-1|NCC|2.54|30|0|Auto|0|1|0|2|0|0|2|0|False|0|0" "|")) 2 1 Quote
CyberAngel Posted July 1, 2024 Posted July 1, 2024 The string-handling functions in AutoLISP are not the best. car won't help unless you have a list. So let's make a list. Add quotes at beginning and end. Replace each pipe with quote-space-quote. Pull out the third element. Done. 1 Quote
ronjonp Posted July 1, 2024 Posted July 1, 2024 Here's another: (mapcar 'vl-princ-to-string (read (strcat "(" (vl-string-translate "|" " " "-1|NCC|2.54|30|0|Auto|0|1|0|2|0|0|2|0|False|0|0") ")") ) ) ;; ("-1" "NCC" "2.54" "30" "0" "AUTO" "0" "1" "0" "2" "0" "0" "2" "0" "FALSE" "0" "0") 2 Quote
Steven P Posted July 1, 2024 Posted July 1, 2024 (edited) You could look at Lee Macs string to List function, use the | character as the deliminator: https://lee-mac.com/stringtolist.html (almost the same as what RLX has) Edited July 1, 2024 by Steven P 1 Quote
rlx Posted July 1, 2024 Posted July 1, 2024 I do like ronjonp's version , its a few characters less code and I'm a BIG fan of short(er) code for my tiny lisp toolbox Quote
BIGAL Posted July 2, 2024 Posted July 2, 2024 (edited) I am a big fan of Lee Mac make a list as suggested. ; tab 9 space 32 comma 44 semicolum 59 | 124 ; thanks to Lee-mac for this defun (defun csv->lst ( str / pos ) (if (setq pos (vl-string-position 32 str)) (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2)))) (list str) ) ) I often rename to suit delimeter. ; tab 9 space 32 comma 44 semicolum 59 | 124 : 58 ; thanks to Lee-mac for this defun (defun csv->lst124 ( str / pos ) (if (setq pos (vl-string-position 124 str)) (cons (substr str 1 pos) (csv->lst124 (substr str (+ pos 2)))) (list str) ) ) Edited July 2, 2024 by BIGAL Quote
ronjonp Posted July 2, 2024 Posted July 2, 2024 (edited) On 7/1/2024 at 11:18 PM, rlx said: I do like ronjonp's version , its a few characters less code and I'm a BIG fan of short(er) code for my tiny lisp toolbox Expand One limitation I've found is if one of the the strings start with a period "|.54|". Then it errors out on "misplaced dot on input" Edited July 2, 2024 by ronjonp Quote
rlx Posted July 2, 2024 Posted July 2, 2024 On 7/2/2024 at 3:36 AM, ronjonp said: One limitation I've found is if one of the the strings start with a period "|.54|". Then it errors out on "misplaced dot on input" Expand oh dear.... that's unfortunate , awel , Lee's method is best... like always Quote
ronjonp Posted July 2, 2024 Posted July 2, 2024 On 7/2/2024 at 6:17 AM, rlx said: Lee's method is best... like always Expand That's usually the case! 1 Quote
Sharper Posted July 3, 2024 Author Posted July 3, 2024 Guys thanks a lot for all or your posts, i will look into them all. I'm sorry for the delay responding, my hard drive failed on my system about an hour after i posted, and i'm currently reinstalling all my software. (Happy days). You guys are the best, love how you bounce off each other Quote
