itacad Posted June 29 Share Posted June 29 Hi, I often find myself editing documents that are made up of many files, because their structure was created with the logic of one file = one page. I ask you if there are techniques or lisp for: - move more quickly between the various files in a special window that lists all the files in a folder in a more practical way than normal use of Autocad. - publish all the individual files in PDF in a single operation in order to obtain the document as a whole. Thank you in advance Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 29 Share Posted June 29 (edited) Why not use layouts can insert a model space dwg into a master dwg and say make a layout of the new insert. re make 1 pdf yes use Ghostscript. It’s free. Can take multiple pdf,s and make a single pdf. Edited June 29 by BIGAL Quote Link to comment Share on other sites More sharing options...
itacad Posted June 29 Author Share Posted June 29 because unfortunately it would be useless work as I still have to return the files divided by page... What you suggest is a system I've been using for a long time. I need a way to have a window that allows me to quickly choose which file (page) to go to... And I would need a system to print the individual files and join them in a single step... patience, I'll do as I've always done Quote Link to comment Share on other sites More sharing options...
Danielm103 Posted June 29 Share Posted June 29 Sheetsets? Quote Link to comment Share on other sites More sharing options...
exceed Posted July 2 Share Posted July 2 Put all dwg files into one dwg file as xref or xattach, Double-click the object to edit it. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/multiple-drawings-in-to-single-drawing/m-p/5787221/highlight/true#M334595 https://www.cadforum.cz/en/batch-insert-of-multiple-dwg-files-into-one-tip8966 For printing, use PDF printing with windows option or PUBLISH the original files. https://www.cadtutor.net/forum/topic/85129-a-need-for-info-on-getting-started-plotting-in-batch-from-the-model-tab/#comment-639676 https://www.cadtutor.net/forum/topic/74581-multiplot-pdf-modelspace/page/2/#comment-590739 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 2 Share Posted July 2 Agree with @exceed put your xrefs into a single dwg as a Layout, I have plot layouts and then make into a single PDF as a lisp. The only criteria is the lisp code for plot expects the layouts to be the same Ie title block size and at 0.0. I did 88 layouts in one go, just watch it flash. Can post. Quote Link to comment Share on other sites More sharing options...
