Vijay Posted June 28 Share Posted June 28 After changing the scale , the dimensions of the sketch have to be convert again and again in scale like if i use 1:85 scale in autocad then i have to convert (metric)3m to 3000mm then divide it by 85....!! Is there any way that i can frequently draw and it convert by itself Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 28 Share Posted June 28 It sounds like your model space drawing units is set to meters not millimeters for starters. 1 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 29 Share Posted June 29 1:85 is not a normal metric scale 1:50 or 1:100 would be a ore correct scale. 1 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted June 29 Share Posted June 29 The reason for scaled drawings is so someone with a standard engineering or architectural scale can use them to check distantances on plotted drawings. Like BIGAL pointed out using a scale not found on either of them serves no purpose whatsoever. 1 Quote Link to comment Share on other sites More sharing options...
