Hi guys,
Im new here and i've been searching and even asking chatgpt to help me out but it doesnt seem to work properly. Im working on a SLD (Single Line Diagram) for an electrical project and when wires cross on the diagram, it needs to have a gap on one of the 2 lines. I've tried this lisp command that ChatGPT gave me but with little to no success;
(defun c:BreakAndShorten ( / pt line break_length startpt1 endpt1 startpt2 endpt2)
  (setq break_length 2.5) ; Set your desired shorten length here (2.5 mm in this case)
  (setq line (car (entsel "\nSelect the line to break: ")))
  (setq pt (getpoint "\nSelect the break point: "))
  (if (and line pt)
      (setq startpt1 (polar pt (angle pt (vlax-curve-getStartPoint line)) (- break_length)))
      (setq endpt1 pt)
      (setq startpt2 pt)
      (setq endpt2 (polar pt (angle pt (vlax-curve-getEndPoint line)) break_length))
      (command "BREAK" line startpt1 endpt2)
      (setq line1 (car (entsel "\nSelect the first segment to shorten: ")))
      (setq line2 (car (entsel "\nSelect the second segment to shorten: ")))
      (if line1 (command "LENGTHEN" "DE" (- break_length) line1))
      (if line2 (command "LENGTHEN" "DE" (- break_length) line2))
    (alert "You must select a line and a break point.")
In sum, I want to break one line at a point and then shorten the 2 segments by 2.5mm so it has a 5mm gap without using multiple command everytime
Edited by SLW210
Added Code Tags!
Please use Code Tags for your code. (<> in the editor toolbar)
There are a few break LISPs around.
This has been asked before you can have jump overs or a gap, with a gap its better to use a wipeout or similar rather than break as pline etc is still continous then. Do a Google or a search here found some solutions. "show gap crossing lines autocad lisp"
Edited by BIGAL
Thank you so much guys for everything. The "BreakObjects.lsp" by marko_ribar worked just like I wanted !
