I am a noob regarding AutoLisp.
What i want to do is this : I have drawing where i need to number many blocks. So i use DTEXT and place it near each block and type the number.
Is there a way to automate this procedure ? I want to start a command, place the point of insert for the first block, type the first number, and then just point the next block and it should increment the previous number and place it.
Does this make any sense ?
Awesome, works like a charm. Thanks ASMI.
Now to be very picky, is there a way to auto number using DTEXT instead of attributed blocks ?
I am blind :). I just saw it now. Thank you all.
  • 10 months later...
The asmitools link doesn't work.
Does anybody have a valid link?
Thanks.
LE: found it.
Hi,
Here is a small code in vba. I think it may help you.
Public num As Integer
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "DTEXT" Then
If num = 0 Then
num = InputBox("Please Enter Starting number")
End If
Dim txt As AcadText
Dim po As Variant
po = ThisDrawing.Utility.GetPoint(, "Select Insertion point")
Set txt = ThisDrawing.ModelSpace.AddText(CStr(num), po, 1)
num = num + 1
End If
End Sub
This will generate the increment number while continuos use of DTEXT command. After using of any other command you have to set the starting number.
Have a good day...
KUMAR.....:)
