Considering this graphics card. your thoughts?
XFX GeForce 9600 GSO Fatal1ty 768MB DDR2 PCI-E 2 x Dual-
Link DVI/HDTV Graphics Card - PV-T96O-S1S4
Card made by NVIDEA.
Properties.
Description
XFX GeForce 9600 GSO Fatal1ty 768MB DDR2 PCI-E 2 x Dual-Link
Let people not look down on you because of your age. Being the little
brother to the 9600GT, this sibling will leave you pleasantly surprised
and speechless. Performing similar to a standard XFX NVIDIA GeForce
8800 GTS 640 MB card this card offer users the ultimate Blu-ray and
HD DVD movie experiences as well as makes a great partner for
gaming. Compatible with the PCI-E 2.0 bus architecture this child has
no problems fitting his older brother’s shoes.Features
NVIDIA unified architecture
Full Microsoft DirectX 10 Shader Model 4.0 support
NVIDIA SLI Ready
True 128-bit floating point high dynamic-range (HDR) lighting with
16 x full-screen anti-aliasing
NVIDIA Quantum Effects physics processing technology
PCI Express 2.0
9600 Series single slot solution
Two dual-link DVI outputs support two 2560x1600 resolution displays
NVIDIA PureVideo HD technology
OpenGL 2.0 support
Built for Microsoft Windows Vista
SpecificationGPU
ChipsetnVidia GeForce 9600 GSO with CUDAChip
Clock580MHzShaderClock1450MHz
HDTV Output - Yes
Cooling System Fansink
Memory
Memory (Maximum)768MB 1000MHz DDR2Memory
Width192bit
Interfaces/Ports
Video Card Bus TypePCI Express 2.0DVI Port
2 x Dual-Link DVIS-Video Port
1 x S-VideoTV Out
1 x HDTV
Performance
Pixels per Clock 48
Resolution
Maximum Resolution2560 x 1600 Pixels
System
Driver SupportDirectX 10 Video Standards
OpenGL 2.0
System Requirements
Operating Systems Supported
Microsoft Windows XP/XP x64 Pro/
Vista System Requirements
Minimum Power Supply:
600W
Compliance CertificationsRoHS
Physical
In The Box
S-Video Cable
DVI Adaptor
6-Pin Y Power Cable
Install CD
User Guide
768mb dedicated ram is pretty good, looks like a nice graphics card.
im sure i got an email through the other day from a retailer with this card on offer. sorry but i wouldve deleted it already though im sure it would have been either maplin, dabs, ebuyer or saverstores since they're the ones who send me the most
Cheers 4 the input, now i just got save up the money. :)
yeh NVIDEA is pretty much the "dog's ~xx%x*x" I would go with that Skips
Skip, don't waste your money on that thing unless you're gonna be playing games with it.
Cheers 4 the heads-up. :thumbsup:
Am doin a self-build gaming comp atm.
If you're looking for a card for gaming (UT2k4?!?!) or video encoding/decoding, that seems like a pretty durn good option. If you're looking for CAD, move along...nothing to see here.
If you're looking for a card for gaming (UT2k4?!?!).
YEP - still tryin to figure out how to set up a host game where can be accessed when i'm not online :thumbsup:
Just out of interest what is the best of the best card to get if budget was not an object?
For gaming, probably the GeForce 295GTX. Obviously you'd want to run that in SLI mode, which means buying two of them.
You also need to be very mindful of their power requirements. And the system would likely run both loud and hot (Probably enough to raise the room temperature).
You should keep in mind that the return on investment (ROI) in terms of performance is rarely ever linear. For example, check out this well written performance/value assessment between the AMD Phenom II processers and Intel's Dual Core, Quad Core, and i7 offerings. You can see by looking at their scatter charts that the "early adopter tax" (I.E. new technology having a significantly higher price tag) does not always mean you will have a revolutionary product experience, merely the best that is available to date. It is typically a bad idea to purchase with a "money is no object" mentality. Far better to evaluate your requirements and put in the research to find that which will best suit your needs.
I guess this is not the quite right location to pose this question but I was meaning more for Cad than games. Is their a listing, something along the lines “$$ is no object to budget is a consideration/performance”
I know I have tried to find this out, has anyone else succeeded?
A comparison chart of "ultra" high end, for CAD apps:
http://www.nvidia.com/object/IO_11761.html
Price of the card that is considered the best from Nvidia:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133253
