priyanka_mehta Posted March 20, 2009 Posted March 20, 2009 Hi all, Is there an automatic way to align text as per the alignment of its adjacent line/object. Thanks and Regards, Priyanka Quote
David Bethel Posted March 20, 2009 Posted March 20, 2009 Depending on the entity type, why not use UCS _E prior to creating the text? -David Quote
borgunit Posted March 20, 2009 Posted March 20, 2009 I wrote this a while back. Be aware, the units were for metric. http://mechcad-insider.blogspot.com/2009/03/get-in-align.html Quote
lpseifert Posted March 20, 2009 Posted March 20, 2009 Look for Talon.lsp by the very generous ASMI http://www.asmitools.com/Files/Programs.html Quote
Lee Mac Posted March 20, 2009 Posted March 20, 2009 Look for Talon.lsp by the very generous ASMIhttp://www.asmitools.com/Files/Programs.html ^^ Such a great LISP Quote
priyanka_mehta Posted March 31, 2009 Author Posted March 31, 2009 Thank you all for the help.. Finally i came out with collecting the angle of line using mathematical formula i.e. bearing = tan(inverse) = y2-y1/x2-x1 and provided this bearing to the textobject. Ultimately i wanted to retrieve length, create a text of the length with the same rotation as line hence, it came out to be like this: [b][font=Times New Roman][/font][/b] [font=Times New Roman][size=3][b]‘Collects Length, Creates a text of its length at the midpoint of the line at the same rotation as line[/b] Private Sub cmdlength_Click() On Error Resume Next [b]‘Collects Length[/b] Dim SOS As AcadSelectionSet Dim objSS As AcadSelectionSet Dim intCode(0) As Integer Dim varData(0) As Variant Dim objEnt As AcadEntity Dim entLine As AcadLine Dim entPoly As AcadPolyline Dim entLWPoly As AcadLWPolyline Dim lenstring As String Dim coordstart As Variant Dim basepoint(0 To 2) As Double Dim col As New AcadAcCmColor Call col.SetRGB(127, 0, 0) a = 1 For Each SOS In ThisDrawing.SelectionSets If SOS.Name = "MySS" Then ThisDrawing.SelectionSets("MySS").Delete Exit For End If Next intCode(0) = 0: varData(0) = "LINE,POLYLINE,LWPOLYLINE" ThisDrawing.SelectionSets.Add ("MySS") Set objSS = ThisDrawing.SelectionSets("MySS") objSS.SelectOnScreen intCode, varData If objSS.Count < 1 Then MsgBox "No lines and polylines selected!" Exit Sub End If Dim endPoint As Variant For Each objEnt In objSS Select Case objEnt.ObjectName Case "AcDbLine" Set entLine = objEnt endPoint = entLine.endPoint ' MsgBox endPoint lenstring = Round(entLine.Length) ' MsgBox lenstring ' Case "AcDb2dPolyline" ' Set entPoly = objEnt ' coord = entPoly.Coordinate(0) ' lenstring = Round(entPoly.Length) ' MsgBox lenstring Case "AcDbPolyline" Set entLWPoly = objEnt ' endPoint = entLine.endPoint coordend = entLWPoly.Coordinate(1) coordstart = entLWPoly.Coordinate(0) x1 = coordstart(0) y1 = coordstart(1) x2 = coordend(0) y2 = coordend(1) 'MsgBox x1 & "," & y1 midpoint = (coordend(0) + coordstart(0)) / 2 & " , " & (coordend(1) + coordstart(1)) / 2 ' entLWPoly.Rotate midpoint, rotationAngle lenstring = Round(entLWPoly.Length) x = (coordend(0) + coordstart(0)) / 2 y = (coordend(1) + coordstart(1)) / 2 [b]‘Collects rotation angle of line[/b] bearing = (y2 - y1) / (x2 - x1) bearing = Atn(bearing) End Select Dim textobj As AcadText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double ' Define the text object textString = lenstring insertionPoint(0) = x: insertionPoint(1) = y + 15: insertionPoint(2) = 0 height = 22 ' Create the text object in model space Set textobj = ThisDrawing.ModelSpace.AddText(textString & "m", insertionPoint, height) textobj.Rotation = bearing ' If bearing = 0 Then ' textobj.Rotation = 0 ' End If textobj.TrueColor = col textobj.StyleName = "ArialBold" Next [/size][/font] I still have a problem,,, i ve created all this in a VB form and there are a lot other buttons for various purposes in this form... To access it I am using a .lsp (vl-load-com)(defun C:APID()(vl-vbarun "Path\\Projectdvb!initialize")) But, i have to hard code the path for this.. is it possible to create a DLL or some exectuable of VB form Thanks and Regards, Priyanka Quote
