JimmyJohn Posted June 26 Share Posted June 26 (edited) ```c (defun replaceall (old new / regex) ;; Create the regex object (setq regex (vlax-get-or-create-object "VBScript.RegExp")) (vlax-put-property regex 'global :vlax-true) (vlax-put-property regex 'ignorecase :vlax-true) (vlax-put-property regex 'multiline :vlax-true) ;; Set the pattern to match exact word (vlax-put-property regex 'pattern (strcat "\\b" old "\\b")) ;; Process every block (vlax-for n (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vlax-for m n (if (member (vla-get-objectname m) '("AcDbMText" "AcDbText")) (progn (setq original-text (vla-get-textstring m)) (setq new-text original-text) ;; Replace using regex only if there's a match (setq replaced-text (vlax-invoke regex 'replace original-text new)) ;; Only update if there was a change (if (/= original-text replaced-text) (vla-put-textstring m replaced-text) ) ) ) ) ) (princ "Replacement done.") ) ``` This AUTOLISP Routine does almost exactly what I want it to. It searches through blocks for exact string, and attempts to replace that exact string with an exact replacement. However I am running into the problem that no matter what I try, I cannot get the output to be what i want. For example, running this code with the inputs (replaceall "1" "vanilla pudding") attempts to replace all instances of "1" by itself in the blocks with "vanilla pudding." However if there is a string in the block "1 Sprinkles", Ideally if you use the input above the output would end up being "vanilla pudding sprinkles". I want this to be able to completely decode a block given predefined inputs. I am not understanding the resources online, and would like some assistance with understanding if possible! Edited June 26 by SLW210 Added Code Tags! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 26 Share Posted June 26 Please use Code Tags in the future. (<> in the editor toolbar) I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 26 Share Posted June 26 @JimmyJohn Use VL-STRING-SUBST ( only replaces the first occurrence ) (vl-string-subst "vanilla pudding" "1" "1 Sprinkles") ;; "vanilla pudding Sprinkles" Quote Link to comment Share on other sites More sharing options...
JimmyJohn Posted June 26 Author Share Posted June 26 9 minutes ago, ronjonp said: @JimmyJohn Use VL-STRING-SUBST ( only replaces the first occurrence ) (vl-string-subst "vanilla pudding" "1" "1 Sprinkles") ;; "vanilla pudding Sprinkles" I'm sorry but where do I put this? When I tried to replace it with ```vla-put-text-string``` it gave me an error for too few arguments. I am sorry I am new to Autolisp and coding in general. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 26 Share Posted June 26 (edited) ;; Substitute text within blocks (defun _foo (old new / a d txt) (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object)))) (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a)))) ) (vlax-for b (vla-get-blocks d) ;; This line will only process block definitions (if (= 0 (vlax-get b 'isxref) (vlax-get b 'islayout)) (vlax-for o b (if (and (vlax-write-enabled-p o) (wcmatch (strcase (vla-get-objectname o)) "*TEXT*") (wcmatch (setq txt (vla-get-textstring o)) (strcat "*" old "*")) ) (vla-put-textstring o (vl-string-subst new old txt)) ) ) ) ) ;; Relock layers (foreach l a (vlax-put l 'lock -1)) ;; Regen to see changes (vla-regen d 1) (princ) ) ;; Usage (_foo "1" "vanilla pudding") Edited June 26 by ronjonp Quote Link to comment Share on other sites More sharing options...
JimmyJohn Posted June 26 Author Share Posted June 26 21 minutes ago, ronjonp said: ;; Substitute text within blocks (defun _foo (old new / a d txt) (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object)))) (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a)))) ) (vlax-for b (vla-get-blocks d) ;; This line will only process block definitions (if (= 0 (vlax-get b 'isxref) (vlax-get b 'islayout)) (vlax-for o b (if (and (vlax-write-enabled-p o) (wcmatch (strcase (vla-get-objectname o)) "*TEXT*") (wcmatch (setq txt (vla-get-textstring o)) (strcat "*" old "*")) ) (vla-put-textstring o (vl-string-subst new old txt)) ) ) ) ) ;; Relock layers (foreach l a (vlax-put l 'lock -1)) ;; Regen to see changes (vla-regen d 1) (princ) ) ;; Usage (_foo "1" "vanilla pudding") Yes this is great! And you are right I completely overlooked the fact it would change on sheets. That would have been embarrassing. There is one thing that happens, if there happens to be a 1 in the string elsewhere, it turns that into vanilla pudding. So if there is an 11 somewhere in the string it turns into "vanilla puddingvanillapudding". How would you go about making it so that if I input (_foo "1" "vanilla pudding") It will only change individual "1" 's in strings to vanilla pudding? Just to be as clear as possible, if the string in the block was 1 2 3 4 5, after I run this code with the input above I would like it to be vanilla pudding 2 3 4 5. Is that possible? What has to be changed or added? Thank you for your help so far! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 27 Share Posted June 27 @JimmyJohn If the string is "11" the result would be "vanilla pudding1" What would this string look like "1 2 3 4 5 1" ? A stated above vl-string-subst only changes the first occurrence. Quote Link to comment Share on other sites More sharing options...
