Mountain_XD Posted June 26 Share Posted June 26 Some body help me Draw Pline by Pick A, B, C, D,E. Thank you very much ! Draw Pline by Pick A, B, C, D,E.dwg Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 26 Share Posted June 26 If the user has to provide the points, can't you just use the PLine command? Or call it with the AutoLISP command command? What am I missing? 1 Quote Link to comment Share on other sites More sharing options...
pkenewell Posted June 26 Share Posted June 26 Based on what your drawing shows. I recommend that you look at this program from Lee Mac: https://www.lee-mac.com/objectbreak.html At the top of the program file, you can set the layer properties of the changed portions of the objects. 1 Quote Link to comment Share on other sites More sharing options...
Mountain_XD Posted June 27 Author Share Posted June 27 13 hours ago, CyberAngel said: If the user has to provide the points, can't you just use the PLine command? Or call it with the AutoLISP command command? What am I missing? I want to Draw Pline with Lisp. Thanks ! Quote Link to comment Share on other sites More sharing options...
