priyanka_mehta Posted March 20, 2009 Posted March 20, 2009 Hi, I have a code that retrieves length of a line by selection and places this length as a text. The position for placement of text is done by .getpoint. Hence I have to click the line twice, once to retreive the length and another time to get the insertion point to place the text. Please help me with this such that in one click i should have length as well as insertion point of that place for placing text Below is the code: Dim SOS As AcadSelectionSet Dim objSS As AcadSelectionSet Dim intCode(0) As Integer Dim varData(0) As Variant Dim objEnt As AcadEntity Dim entLine As AcadLine Dim entPoly As AcadPolyline Dim entLWPoly As AcadLWPolyline Dim lenstring As String a = 1 For Each SOS In ThisDrawing.SelectionSets If SOS.Name = "MySS" Then ThisDrawing.SelectionSets("MySS").Delete Exit For End If Next intCode(0) = 0: varData(0) = "LINE,POLYLINE,LWPOLYLINE" ThisDrawing.SelectionSets.Add ("MySS") Set objSS = ThisDrawing.SelectionSets("MySS") objSS.SelectOnScreen intCode, varData If objSS.Count < 1 Then MsgBox "No lines and polylines selected!" Exit Sub End If Dim endPoint As Variant For Each objEnt In objSS Select Case objEnt.ObjectName Case "AcDbLine" Set entLine = objEnt endPoint = entLine.endPoint lenstring = Round(entLine.Length) ' MsgBox lenstring Case "AcDb2dPolyline" Set entPoly = objEnt lenstring = Round(entPoly.Length) ' MsgBox lenstring Case "AcDbPolyline" Set entLWPoly = objEnt lenstring = Round(entLWPoly.Length) ' MsgBox lenstring End Select Next '******************************************************************************************* '******************************************************************************************* '******************************************************************************************* Dim Point As Variant Dim x As Double Dim y As Double Dim z As Double On Error Resume Next 'hide the UserForm frmKP.Hide 'ask user to select a point Point = ThisDrawing.Utility.GetPoint(, "Select a point") x = Point(0): y = Point(1): z = Point(2) 'redisplay the UserForm frmAPId.Show 'MsgBox x 'MsgBox y '********************************************************************************************** '******************************************************************************************* '******************************************************************************************* Dim textObj As AcadMText Dim textobj1 As AcadMText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double Dim textstring1 As String ' Define the text object textString = Round(lenstring, 2) '& vbCr & Round(txty.Value) insertionPoint(0) = x: insertionPoint(1) = y: insertionPoint(2) = 0 height = 22 'MsgBox textString Set textObj = ThisDrawing.ModelSpace.AddText(textString & " m", insertionPoint, height) Thanks and Regards, Priyanka Quote
SEANT Posted March 20, 2009 Posted March 20, 2009 Instead of using a selection set you could use the ThisDrawing.Utility.GetEntity method. That method will return the point used to make the entity selection. It will only work for one entity at a time, however. Quote
ska67can Posted March 20, 2009 Posted March 20, 2009 Where, in relation to the line, do you want to place the text? ska Quote
