Well, I suppose the quickest way to combine them would be just this:
(defun c:pz ()
 (command "_.layer" "m" "test" "c" "4" "" "")
 (command "_.INSERT" "pz" "s" (getvar "dimscale") PAUSE PAUSE)
(test)
(defun test (/ txt ent)
 (if
   (and
     (/= "" (setq txt (getstring t "\nSpecify Text...")))
     (setq ent (entmakex
                 (list '(0 . "TEXT")
                       (cons 10 '(0 0 0))
                       (cons 40 1)
                       (cons 7 (getvar "TEXTSTYLE"))
                       (cons 1 txt)
    (command "_move" ent "" '(0 0 0) pause)
 (princ "\n<!> No Text Specified <!>")
But obviously you could just write them as one LISP
  • Replies 32
  • neekcotrack
    14
  • Lee Mac
    13
  • CAB
    5
  • Se7en
    1
(defun c:pz ()
(test)
 (if
   (and
     (setq ent (entmakex
                 (list '(0 . "TEXT")
                       (cons 10 '(0 0 0))
                       (cons 40 1)
                       (cons 1 txt)
I can't get this to work. After I insert the text loop and then type in what I want it to say it comes up with "No Text Specified"
Sorry, bracket was wrong :(
(defun c:pz  ()
 (test)
 (if
   (and
     (setq ent    (entmakex
         (list    '(0 . "TEXT")
           (cons 10 '(0 0 0))
           (cons 40 1)
           (cons 1 txt)))))
    (princ "\n<!> No Text Specified <!>"))
 (princ))
It still does the same thing
Here is the info in the command line it keeps giving me.
Command: pz
_.layer
Current layer: "test"
Enter an option
[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/MATerial/Plot/Freeze/Thaw/LOck/Unlock
/stAte]: m
Enter name for new layer (becomes the current layer) : test Enter an
option
/stAte]: c
New color [Truecolor/COlorbook] : 4
Enter name list of layer(s) for color 4 (cyan) : Enter an option
/stAte]:
Command: _.INSERT Enter block name or [?] : pz
Units: Inches Conversion: 0'-1"
Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: s Specify scale
factor for XYZ axes : 96.00000000000001 Specify insertion point or
Specify rotation angle :
Enter attribute values
1i":
Specify Text...1234
No Text Specified
1i":
Verify attribute values
1i":
Are you trying to place some text halfway through Inserting a Block???
I am trying to insert the block where I want it and then insert some text and put it where I want it.
Maybe:
(defun c:pz  (/ *error ovar vlst ent txt)
 (defun *error*  (msg)
   (if    ovar
     (mapcar 'setvar vlst ovar))
   (princ (strcat "\nError: " (strcase msg)))
   (princ))
 (setq    vlst '("CMDECHO" "ATTREQ")
   ovar (mapcar getvar vlst))
 (mapcar 'setvar vlst '(0 0))
 (if (and (/= "" (setq txt (getstring t "\nSpecify Text...")))
      (setq ent (entmakex
              (list '(0 . "TEXT")
                (cons 10 '(0 0 0))
                (cons 40 1)
                (cons 1 txt)))))
 (princ))
Maybe:
   (if    ovar
   (princ))
      (setq ent (entmakex
              (list '(0 . "TEXT")
                (cons 10 '(0 0 0))
                (cons 40 1)
                (cons 1 txt)))))
 (princ))
It comes up with "BAD FUNCTION: #"
Ahhh, my carelessness - I missed an apostrophe - its so hard to spot these things when you don't test the routines...
   (if    ovar
   (princ))
   ovar (mapcar 'getvar vlst))
      (setq ent (entmakex
              (list '(0 . "TEXT")
                (cons 10 '(0 0 0))
                (cons 40 1)
                (cons 1 txt)))))
 (princ))
   (if    ovar
   (princ))
      (setq ent (entmakex
              (list '(0 . "TEXT")
                (cons 10 '(0 0 0))
                (cons 40 1)
                (cons 1 txt)))))
 (princ))
Its acting weird. I am trying to do this:
1. type "PZ" to run command
2. Pick insertion point of Text loop
3. Pick point of angle
4. Type desired Text
5. Insert Text
6. End command
I hope this makes more sense now.
what you you mean by, its acting weird, what is it doing wrong exactly?
When I insert the text loop it is not there ,then the test comes in at the same angle at the text loop.
Would you be able to post a sample of the block you are using, so I could see what you are trying to achieve?
