Line variable
maahee
(command "line" p1 "@12<90" "")
To
(setq rm (getdist "\nEnter room height or [undo]: "))
(setq bm rm)
(command "line" p1 "@bm<90" "")
(if (= wp "Partially")
         (setq wf 0)
         (setq wf (- rm ws 0.10 wh))
  (setq p13 (polar p1  (+ (angle p1 p2) (* pi 0.5))(- ws 0.10)))
  (setq p14 (polar p13 (+ (angle p1 p2) (* pi 0.5)) 0.10))
  (setq p15 (polar p14 (+ (angle p1 p2) (* pi 0.5)) wh))
  (setq p16 (polar p15 (+ (angle p1 p2) (* pi 0.5)) 0.10))
  (setq t16 (polar p16 (+ (angle p1 p2) (* pi 0.5)) wf)) ;;;;;;;;;;;;;do not run (if (= wp "Partially")
1.  In this statement "@12<90" . I want to set 12 number variable,,, also
2.  if wrong room height enter then run undo function by user (one step back or more)
3.   (setq t16 (polar p16 (+ (angle p1 p2) (* pi 0.5)) wf))   ;;;;;;;;;;;;; do not run (if (= wp "Partially")
Edited by maahee
If it is in quotes, " " it is seen as a string, you'll want to create the string with something like:
(command "line" p1 (strcat "@" (rtos bm) "<90") "")
  • Thanks 1
Two other ways
(command "LINE" p1 (mapcar '+ p1 (list 0.0 BM 0.0)))  ; (list x y 0.0)
(command "LINE" p1 (polar p1 (/ pi 2.) bm))
Edited by BIGAL
  • Thanks 1
