itacad Posted June 19 Share Posted June 19 Hi, I can't perform an operation that I consider trivial and that is a quick selection of all the dimensions with the same dimension style. For this type of operation there is the qselect command, but it doesn't seem to work In the "object type" menu it offers "rotated dimension" and not a simple and banal dimension and by choosing "rotated dimension" I am unable to select any object Thanks for any suggestions Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 19 Share Posted June 19 Here's a potential solution. It's a little clunky, but it worked for me. Use the FILTER command. In the "select filter" pane, choose "dimensions" then "Add to List". Press the "Apply" button. You're asked to select objects. You can use any legitimate option, such as a window, "ALL", or whatever you prefer. Because of the filter, though, you only select the dimensions. You have the option to add "dimension style" to your filter. That may allow you to do what you want. If filtering doesn't work, someone may be able to whip up a quick LISP function for you. In fact, Lee Mac has probably already written it. Quote Link to comment Share on other sites More sharing options...
itacad Posted June 20 Author Share Posted June 20 Thanks, I know the filters and I use them, they are very powerful so I knew this solution but I was thinking I was doing something wrong with qselect Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 20 Share Posted June 20 47 minutes ago, itacad said: Thanks, I know the filters and I use them, they are very powerful so I knew this solution but I was thinking I was doing something wrong with qselect Well, if it's any consolation, something similar happened to me. I selected one dimension, but when I used Select Similar, I got zero results. Apparently, dimensions aren't even similar to themselves. Even a dynamic block is similar to itself. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 21 Share Posted June 21 I drew 3 dims HOR, VER & Aligned if you look at dxf code 3 = dimension style but multiple 100 codes the ver & hor were AcDbRotatedDimension" but the aligned was "AcDbAlignedDimension" so could do a lisp defun that has specific dimension properties and makes a selection set matching. Quote Link to comment Share on other sites More sharing options...
