I'm trying to run the command "_pline" of the selected line type through Lisp, which
would be entered onto a specific layer, and upon completion the current one would be returned
layer. I'm a novice in programming, I try but in vain. Maybe someone can fix it?
I would be very grateful.
(defun C:gass ( / cl )
(if (not (tblsearch "LTYPE" "GASs")
(command "_-linetype" "_l" "GASs" "truba.lin" "_s" "GASs" "")
(if (/= (getvar "CELTYPE") "GASs")(setvar "CELTYPE" "GASs"))
(setq cl (getvar "CLAYER" "0"))
(command "_-layer" "_m" "PIPELINES" "")
(command "_pline")
(while (= (getvar "cmdactive") 1)(command pause))
(setvar "CLAYER" cl))))
(C:gass)
(defun C:feces( / cl )
(if (not (tblsearch "LTYPE" "Sewerage")
(command "_-linetype" "_l" "Sewerage" "truba.lin" "_s" "Sewerage" "")
(if (/= (getvar "CELTYPE") "Sewerage")(setvar "CELTYPE" "Sewerage"))
(command "_-layer" "_m" "SEWERAGE" "")
(command "_pline")
(C:feces)
Edited by SLW210
Added Code Tags!
Please use Code Tags (<> in the editor toolbar) in the future.
(defun c:gass ( / cl clt ltypename layername)
	(setq ltypename "GASs")
	(setq layername "PIPELINES")
	(setq clt (getvar "CELTYPE")) ; Get active linetype
	(if (not (tblsearch "LTYPE" ltypename)) ; If linetype does not exist
		(command "_-linetype" "_l" ltypename "truba.lin" "_s" ltypename "") ; Create it
	(if (/= (getvar "CELTYPE") ltypename) ; If linetype is not active
		(setvar "CELTYPE" ltypename) ; Activate it
	(setq cl (getvar "clayer")) ; Get active layer
	(if (not (tblsearch "LTYPE" layername)) ; If layer does not exist
		(command "_-layer" "_m" layername "") ; Create it
	(if (/= (getvar "CLAYER") layername) ; If layer is not active
		(setvar "CLAYER" layername) ; Activate it
	(command "_pline") ; Start command
	(while (= (getvar "cmdactive") 1) ; As long as command is active, pause
		(command "\\")
	(setvar "CELTYPE" clt) ; Activate it
	(setvar "CLAYER" cl) ; Reset layer to what it was before this function
I've added some comments, hopefully this makes it more clear what is happening.
And it would make a nice challenge to fix the second one yourself 😁
Edited by dexus
(defun c:gass ( / var vals)
  (setq var (list "CELTYPE" "CLAYER")
        val (mapcar 'getvar var)
  (if (not (tblsearch "LTYPE" "GASs")) ;idk if this will error if existing so left this check in but could prob take it out also
  (setvar 'celtype "GASs")
  (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "PIPELINES") (70 . 0) (62 . 1) (290 . 0))) ;change 62 to the coler you want
  (setvar 'clayer "PIPELINES")
  (command "_pline")
    (command "\\")
  (mapcar 'setvar var vals)
@dexus added a mapcar to set an return variables
Maybe someone can correct me but I don't check for current layer just issue the change.
Also try not to use command when possible entmake for the layer.
@boretskiy if statements in lisp only run the first two lines of code.
(if condition
  then-part
  [else-part]
to run multiple lines of code you would have to wrap them with (progn
You also need to match up ( ) for the code to even load. I recommend getting notepad++ it will color code things for you so its easier to track down
    (command "_-linetype" "_l" "GASs" "truba.lin" "_s" "GASs" "") ;if true do this
    ;false isn't needed to run
      (prompt "\nGASs line Type already in the drawing")
Also don't have  commands outside of functions (C:feces)  (C:Gass) this calls the command when the lisp is loaded. Seeing its needs user input it would just wait their until you cancel the command. its not needed to close a function.
