LievenC Posted June 13 Share Posted June 13 Hello, I am new to lisp. I found somewhere a lisp for incrementing the counter value in the bubble mleader. It is not working. I tried analyzing the code but could not detect where it is not functional looks like the incrementing number is nog working As I only have Autocad LT 2025 I cannot debug this. If someone could help me solving the issue and in the same time add some comments to the lisp BubbleInc.zip Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 13 Share Posted June 13 I moved your thread to the AutoLISP, Visual LISP & DCL Forum. That is VLISP (Visual LISP) and LT will not run VLISP which is why it doesn't have the VLIDE (Visual LISP Editor). Maybe someone has a work around for 2025LT. Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 13 Share Posted June 13 LT had some LISP functions added in 2024, but not the full set. I think this LISP, written in 2011 before LT has LISP functionality, has some functions that LT doesn't recognise such as vla-get-acad-object Here is a quick summary: https://www.cadlinecommunity.co.uk/hc/en-us/articles/10203677758877-AutoCAD-LT-2024-is-out-What-s-New-A-first-look Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 15 Share Posted June 15 There is not much VL in it but I would start at (setq style "BUBBLE" ; MLeader style (with single attribute block) so this is looking for a mleader style called "BUBBLE" and if it does not exists code does not run. You have to have the Bubble style or you need a check does it exist if not make it. Quote Link to comment Share on other sites More sharing options...
