I hope someone can help to combine 2 function Autolisp
Kvlar
I have 2 autolisp codes with functions: explode and overkill.
Explode to break objects and overkill to delete duplicate lines.
Can anyone help me to combine these 2 autolisp functions? So I only need to do 1 command by selecting the object 1 time but already running the explode and overkill functions simultaneously.
Thank you
Code for explode:
(defun c:xpl1 (/ sel qaf)
   (setq qaf (getvar "qaflags"))
   (setq sel (ssget))
   (sssetfirst sel sel)
   (setvar "QAFLAGS" 1)
   (command "explode" sel)
   (setvar "QAFLAGS" qaf)
Code for overkill:
(defun getOrder ( / doc spc dic sort order )
 (vl-load-com)
 (setq doc (vla-get-activeDocument (vlax-get-acad-object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
 (if (vl-catch-all-error-p (setq sort (vl-catch-all-apply 'vla-item (list (setq dic (vla-getextensiondictionary spc)) "ACAD_SORTENTS"))))
   (setq sort (vla-addobject dic "ACAD_SORTENTS" "AcDbSortentsTable"))
 (vla-getfulldraworder sort 'order :vlax-false)
 (if (< 0 (vlax-safearray-get-u-bound order 1))
   (vlax-safearray->list order)
(defun ssorder ( / s ss )
 (vl-load-com)
 (setq s (ssget "_:L" '((0 . "*POLYLINE,SPLINE,HELIX,LINE,ARC,CIRCLE,ELLIPSE"))))
 (setq ss (ssadd))
 (foreach e (reverse (mapcar (function vlax-vla-object->ename) (getOrder)))
   (if (ssmemb e s)
     (ssadd e ss)
 ss
(defun c:ovr1 nil
 (vl-cmdf "_.-OVERKILL" (ssorder) "" "_O" 1e-6 "_I" "_A" "_P" "_Y" "")
Thank you
Code for explode:
   (setq sel (ssget))
Code for overkill:
 (vl-load-com)
 (vl-load-com)
 (setq ss (ssadd))
   (if (ssmemb e s)
     (ssadd e ss)
 ss
(defun c:ovr1 nil
@Kvlar Try this
(defun c:foo (/ ssorder getorder qaf sel)
  (defun getorder (/ doc spc dic sort order)
    (vl-load-com)
    (setq doc (vla-get-activedocument (vlax-get-acad-object))
		       'vla-item
  (defun ssorder (/ s ss)
    (vl-load-com)
    (setq ss (ssadd))
    (foreach e (reverse (mapcar (function vlax-vla-object->ename) (getorder)))
      (if (ssmemb e s)
	(ssadd e ss)
    ss
  (setq sel (ssget))
thanks for the help. but after I tried the code, it didn't work as I needed
but I think my source code is wrong
9 hours ago, ronjonp said:
@Kvlar Try this
    (vl-load-com)
		       'vla-item
    (vl-load-com)
    (setq ss (ssadd))
      (if (ssmemb e s)
	(ssadd e ss)
    ss
  (setq sel (ssget))
This code is almost similar to this:
(defun c:test ( / )
        (c:xpl1)
        (c:ovr1)
This requires selecting the object twice. what I need is to select the object once with the explode and overkill functions
I did not check that what you posted actually works.
but, is it possible select the object once with the explode and overkill functions?
I use entlast as a place marker then anything created/modified after that you can process using entnext
(setq ss (ssadd))  ; Create an empty selection set
(setq LastEnt (entlast))  ;Get the last entity in the drawing
;explode code
(while (setq LastEnt (entnext LastEnt)) ; Add all entity's created/modified after setting lastent to the selection set
  (ssadd LastEnt ss)
;explode code
  (ssadd LastEnt ss)
Is this like doing selection only one time at the beginning, then command 1 will be done, the result will be taken automatically by Lisp and used by Command 2 ?
I tried to make the code simpler.
this code:
(defun c:subf5a (/ ss i ent obj)
  (setq ss (ssget "_:L" '((0 . "LINE,ARC,LWPOLYLINE,LINE")))) ; Selects lines, arcs, and polylines
  (if ss
        (setq ent (ssname ss (setq i (1- i))))
        (setq obj (entget ent))
        (if (= (cdr (assoc 0 obj)) "LWPOLYLINE")
          (command "_explode" ent "")
          (command "EXPLODE" ent)
  (command "_.-OVERKILL" "_all" "" "_Done") ; Runs OVERKILL on all objects
but I have a problem. How do I make the overkill command only apply to the object I selected?
I think the problem is with the "_all" argument. but I don't know what to change it so that the overkill command only applies to the object I selected.
I hope you can help me
Try this
(defun C:Foo (/ ss)
  (if (setq SS (ssget "_:L" '((0 . "LINE,ARC,LWPOLYLINE,LINE")))) ; Selects lines, arcs, and polylines
      (command "_explode" SS "")
        (ssadd LastEnt ss)
  (command "_.OVERKILL" SS "" "_Done") ; Runs OVERKILL on all objects
27 minutes ago, mhupp said:
Try this
(defun C:Foo (/ ss)
        (ssadd LastEnt ss)
This code is good, but I don't want to show this overkill settings popup. I want to set the overkill setting in the autolisp code.
example like this (command "_.OVERKILL" SS "" "_O" 1e-6 "_I" "_A" "_P" "_Y" "")
but I don't know what argument I should use to set the overkill setting
Edited by Kvlar
