jacksoncarl5 Posted June 11 Share Posted June 11 I have a named view "name3" that I want to insert on my layout sheet Layout2. I could not find a way to insert it directly the best I could do is the code below where I insert a viewport and hardcode the target, however I get very mixed results and the viewports generated do not match the named view, so I would really like to insert it directly. Sub InsertNamedViewIntoLayout() Dim doc As AcadDocument Dim layout As AcadLayout Dim view As AcadView Dim viewName As String Dim layoutName As String Dim layoutIndex As Integer Dim mtextObj As AcadMText ' Get the current document Set doc = ThisDrawing ' Specify the layout name where you want to insert the named view layoutName = "Layout2" ' Find the layout by name and get its index For layoutIndex = 0 To doc.Layouts.Count - 1 If doc.Layouts.Item(layoutIndex).Name = layoutName Then Exit For End If Next layoutIndex ' Specify the named view to insert viewName = "name3" ' Find the named view For Each view In doc.Views If view.Name = viewName Then ' Activate the layout ThisDrawing.ActiveLayout = ThisDrawing.Layouts("Layout2") ' Get the layout object again after activation Set layout = doc.Layouts.Item(layoutIndex) ' Insert the named view into the layout Dim insertPoint(0 To 2) As Double insertPoint(0) = 0 insertPoint(1) = 0 ' Insert layout view here Dim pViewport As AcadPViewport Set pViewport = layout.block.AddPViewport(insertPoint, 1, 1) ' Link viewport to modelspace Dim direction(0 To 2) As Double direction(0) = 0 direction(1) = 0 direction(2) = 0 pViewport.direction = direction Dim target(0 To 2) As Double target(0) = 872369 - 129 target(1) = 1266978 target(2) = 0 pViewport.target = target pViewport.ViewportOn = True pViewport.CustomScale = 1 / 96 pViewport.Height = view.Height ' You might need to adjust this value according to your model size pViewport.Width = view.Width ' You might need to adjust this value according to your model size ' Add text to the layout Set mtextObj = layout.block.AddMText(insertPoint, 20, "Hello World") mtextObj.Height = 200 mtextObj.BackgroundFill = True ' Regenerate the layout to update changes doc.Regen acAllViewports ' Refresh the screen doc.Application.ZoomAll Exit For End If Next view ' Cleanup Set doc = Nothing Set layout = Nothing Set view = Nothing End Sub Quote Link to comment Share on other sites More sharing options...
jacksoncarl5 Posted June 11 Author Share Posted June 11 I have tried setting pViewport.target = view.target and pViewport.direction = view.direction but this did not work either, according to the debugger view.direction = (0,0,1) and view.target is (0,0,0) but this is not what is in the named view the named view is centered at the hardcoded values. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 12 Share Posted June 12 I scratch the surface of VBA but look carefully at code below Dim insertPoint(0 To 2) As Double I think that is where your problem is. Quote Link to comment Share on other sites More sharing options...
