If this is a new question it would be better if it was placed in a new thread. :thumbsup:
What needs replacing? and what with?
Helle Lee,
I like to insert parenthesis ( Brackets) into several text .is it possible to do this by using find and replace command.
like if I put * (star) in to the find box .It will select all text. and then I put (*) into replace box. because i do not change any individual text.
But it did not work.
  • Replies 144
  • Lee Mac
    58
  • au-s
    23
  • JeepMaster
    9
  • wakibd
    7
Hello Dave,
regards
Racel
Try this:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ptxt  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss tStr[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"X"[/color][/b]
                     [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"*TEXT"[/color][/b][b][color=RED])[/color][/b]
                           [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b][b][color=RED])[/color][/b]
                             [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]410[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                             [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]67[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TILEMODE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] eLst  [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tStr [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]40[/color][/b][b][color=RED])[/color][/b] tStr [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]41[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> No Text Found <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Hello
It's a long time i make lisp :D
You have several on this page. Just take the time to translate.
For the lisp pat, I'm just used to objectdbx.:wink:
Nothing really wizard.
Thats a generous donation Patrick :)
I suppose its because I have only just started moving into VL and so am not really experienced in this kind of programming.
Cheers
Lee
Continuous at vlisp is power AutoLISP by 10 :shock:
You can enable things unimaginable.
The only limit with this language is imagination.
An example that much fun and shows some of the possibilities :D
(defun autocad_qui_parle (texte / sapi)
 (setq sapi (vlax-create-object "Sapi.SpVoice"))
 (vlax-invoke sapi "Speak" texte 0)
 (vlax-release-object sapi)
(defun autocad_qui_parle_debut (rea cde)
 (autocad_qui_parle (strcat "Command ," (car cde) " will start"))
(defun autocad_qui_parle_inconnu (rea cde)
 (autocad_qui_parle (strcat "Unknown command ," (car cde)))
(defun autocad_qui_parle_cancel (rea cde)
 (autocad_qui_parle (strcat "Command ," (car cde) " Cancelled"))
(defun autocad_qui_parle_failed (rea cde)
 (autocad_qui_parle (strcat "Command ," (car cde) " failed"))
(defun autocad_qui_parle_fin (rea cde)
 (autocad_qui_parle (strcat "Commande ," (car cde) " ended"))
(if (not pourrir_la_vie)
 (setq pourrir_la_vie (vlr-command-reactor nil (list    (cons :vlr-commandWillStart (function autocad_qui_parle_debut))
                                  (cons :vlr-unknownCommand   (function autocad_qui_parle_inconnu))
                                  (cons :vlr-commandCancelled (function autocad_qui_parle_cancel))
                                  (cons :vlr-commandFailed    (function autocad_qui_parle_failed))
                                  (cons :vlr-commandEnded     (function autocad_qui_parle_fin))
A mixture of activex and reactors
To remove reactors
(vlr-remove pourrir_la_vie)
Patrick, how long have you been programming? Your programs are always so advanced :D
Hello Lee,
Thanks for your lisp program.
But still i have the problem. I have to put dia signs (%%C) in envery text.
Is it possible to do selection the text ( which text I want) from set of texts and put sign or parenthesis or coma or full stop at the end or begins or both side of the texts. If you have the lisp program please post it.
Thanks again
Wakibd,
I just made a "blanket" program that would add parentheses (brackets) at the beginning and end of every text string. As was requested.
Would you like me to make a program that will give you more options?
Ok, try this :P (turn your speakers on)
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:tupd  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss dLst tmp1 tmp2 tStr[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"*TEXT"[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] dLst [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b]sym:def pos:def[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x y[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]boundp[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]set[/color][/b] x y[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] dLst [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"%%C"[/color][/b] [b][color=#ff00ff]"Front"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tmp1 [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Symbol to be Added <"[/color][/b] sym:def [b][color=#ff00ff]">: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"Front End Both"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tmp2
            [b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Position for Symbol [Front/End/Both] <"[/color][/b] pos:def [b][color=#ff00ff]">:"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x y[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]""[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b]  [b][color=RED]([/color][/b][b][color=BLUE]set[/color][/b] y x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] tmp1 tmp2[b][color=RED])[/color][/b] dLst[b][color=RED])[/color][/b]
                            [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b]
                              [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"Front"[/color][/b] pos:def[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tStr [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] sym:def [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"End"[/color][/b] pos:def[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tStr [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] sym:def[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"Both"[/color][/b] pos:def[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tStr [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] sym:def [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] sym:def[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] tStr[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] eLst[b][color=RED])[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b]funny[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> No Text Selected <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] funny  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] sapi[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sapi [b][color=RED]([/color][/b][b][color=BLUE]vlax-create-object[/color][/b] [b][color=#ff00ff]"Sapi.SpVoice"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-invoke[/color][/b] sapi [b][color=#ff00ff]"Speak"[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]vl-list->string[/color][/b]
     [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]76[/color][/b] [b][color=#009900]101[/color][/b] [b][color=#009900]101[/color][/b] [b][color=#009900]32[/color][/b] [b][color=#009900]77[/color][/b] [b][color=#009900]97[/color][/b] [b][color=#009900]99[/color][/b] [b][color=#009900]32[/color][/b] [b][color=#009900]104[/color][/b] [b][color=#009900]97[/color][/b]
       [b][color=#009900]115[/color][/b] [b][color=#009900]32[/color][/b] [b][color=#009900]117[/color][/b] [b][color=#009900]112[/color][/b] [b][color=#009900]100[/color][/b] [b][color=#009900]97[/color][/b] [b][color=#009900]116[/color][/b] [b][color=#009900]101[/color][/b] [b][color=#009900]100[/color][/b]
       [b][color=#009900]32[/color][/b] [b][color=#009900]121[/color][/b] [b][color=#009900]111[/color][/b] [b][color=#009900]117[/color][/b] [b][color=#009900]114[/color][/b] [b][color=#009900]32[/color][/b] [b][color=#009900]116[/color][/b] [b][color=#009900]101[/color][/b] [b][color=#009900]120[/color][/b] [b][color=#009900]116[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-release-object[/color][/b] sapi[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Hello Lee
Thank you very much for your really nice coding with sound effect.
:thumbsup:
hehe, thought you might like the sound effect :D
Idea came from Patrick's example :)
Hello Lee,
I have another different problem. I am using wipeout command to remove something or portion of the drawing. When I print out it comes fine. But when I do the PDF from the drawing , the wipe out portion of the drawing comes black (in the PDF output).
regards
wakibd
Wakibd,
This question is a lot further from the topic of the original.
When you have new questions it is better to post them in a new thread in the correct forum - that way you will get better answers from all the members of the community.
Lee
  • 3 weeks later...
Hello Lee,
Thanks for ur lisp program .
But I have the problem with my block. I have same tag name for desined, drawn and checked as well all dates but their prompt name are different . how can i put the logic in your lisp program.
I have attached my block.
how can i use this lisp program in several files in one hit
regards
wakibd
TEMPLATE.dwg
I'm not going to attempt to answer your LISP problem but the same tag name in a single block is a recipe for disaster, irrespective of their different prompts. Dynamic blocks get totally confused and I have had problems with VBA. I'll await comments from a LISP coder.
I agree -
The tag name is how I identify different attributes when programming - The prompt is nigh inaccessible from the block instance itself - one much dig much deeper for that.
I would not use the same tag name for all attributes - this is bad practice imo, and will cause you problems in the future.
Lee
  • 3 weeks later...
This may be better suited to you:
(defun c:atest    (/ taglist ss ent att tnme)
 (setq    taglist
    '(("ECA-AREA-NAME" . "TEST1")
      ("ECA-TITLE1"    . "TEST2")) ;  <--- List Tags and Values here.
 (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 "T-A002A")
   (cons 66 1) (if    (getvar "CTAB") (cons 410 (getvar "CTAB"))
     (cons 67 (- 1 (getvar "TILEMODE")))))))
     (foreach ent  (mapcar 'cadr (ssnamex ss))
   (setq att (entnext ent))
   (while (not (eq "SEQEND" (cdadr (entget att))))
     (setq tnme (cdr (assoc 2 (entget att))))
     (if (assoc tnme taglist)
       (entmod (subst (cons 1 (cdr (assoc tnme taglist)))
              (assoc 1 (entget att)) (entget att))))
     (setq att (entnext att))))
     (command "_regenall"))
   (princ "\n<!> No Blocks Found <!>"))
 (princ))
I have used an associative list instead.
You can list your attribute tag names in the list as shown, and what you require them to be changed to.
Hope this helps some more
Lee
Nice one.
Is it possible to make that lisp work with the attedit command.
Instead of having a pre-defined taglist it calls for a command attedit in ACAD then the user changes attribute values wit hattedit command of a given block in lisp like here: T-A002A??
So its block-related but you change it with attedit command
Perhaps something like this?
[i][color=#990099];;; =============== AttChg.lsp ===============[/color][/i]
[i][color=#990099];;; [/color][/i]
[i][color=#990099];;;   FUNCTION: AttChg[/color][/i]
[i][color=#990099];;;   Will synchronise Attributes in Multiple[/color][/i]
[i][color=#990099];;;   Block Instances.[/color][/i]
[i][color=#990099];;;   AUTHOR:[/color][/i]
[i][color=#990099];;;   Lee McDonnell (Lee Mac)[/color][/i]
[i][color=#990099];;;   (Contact at CADTutor.net, TheSwamp.org)[/color][/i]
[i][color=#990099];;;   10th June 2009[/color][/i]
[i][color=#990099];;; ==========================================[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:AttChg [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *error* blkNme tdef bTest attlst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] *error* [b][color=RED]([/color][/b]e[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] ocm [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CMDECHO"[/color][/b] ocm[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]wcmatch[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] e[b][color=RED])[/color][/b] [b][color=#ff00ff]"*CANCEL*,*EXIT*"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< Error: "[/color][/b] e [b][color=#ff00ff]" >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ocm [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CMDECHO"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CMDECHO"[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"Name"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blkNme
       [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Block or [Name]: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-consp[/color][/b] blkNme[b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] blkNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]66[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] blkNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blkNme [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] blkNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Exit Loop[/color][/i]
       [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=DARKRED]'[/color][/b]STR [b][color=RED]([/color][/b][b][color=BLUE]type[/color][/b] blkNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blkNme [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [b][color=BLUE]t[/color][/b] [b][color=#ff00ff]"\nSpecify Block Name: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tdef [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blkNme[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] tdef[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blkNme[b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< Block Contains No Attributes >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< Block Not Found >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Keep in Loop[/color][/i]
       [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nMissed, Try Again..."[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=RED])[/color][/b]
                         [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]2[/color][/b] blkNme[b][color=RED])[/color][/b]
                         [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]66[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]initdia[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vl-cmdf[/color][/b] [b][color=#ff00ff]"_.attedit"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bTest [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] att [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]vla-getAttributes[/color][/b]
                        [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] bTest[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] attlst
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TagString[/color][/b] att[b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TextString[/color][/b] att[b][color=RED])[/color][/b][b][color=RED])[/color][/b] attlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] Att [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b]
                        [b][color=RED]([/color][/b][b][color=BLUE]vla-getAttributes[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Tag [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TagString[/color][/b] Att[b][color=RED])[/color][/b] attlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]vla-put-TextString[/color][/b] Att [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] Tag[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n<< "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sslength[/color][/b] ss[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
                    [b][color=#ff00ff]" Block Instances Updated >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< No Block Instances Found in Drawing >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
thanx Sir!!!
is it possible to "NOT" select block.
Is it possible for that program to skip the block-selection and go instantly to attedit for a specific blockname ... like in previous examples...
(defun c:test1 ()
 (setq blk "stamp")
(command "Attchg" "N" blk)
(defun c:test2 ()
 (setq blk2 "stamp2")
(command "Attchg" "N" blk2)
Above example? Can I do something like that?
So I can call your command and change diffrent block-names?
I get an error
Unknown command "ATTCHG". Press F1 for help.
Unknown command "N". Press F1 for help.
Unknown command "STAMP". Press F1 for help.
Thanx in advance
