aaaaaa13 Posted June 10 Share Posted June 10 Hi, I have a polyline and I want to break it at multiple points. I used break at point, but this way I can select only one point to break the polyline and I also used explode, but this function turns the polyline into lines and I need them to be polylines. There is a way to select multiple points to break the polyline? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 10 Share Posted June 10 If you look at this its the vertice points so dont use the 1st and last point. (setq plent (entsel "\nPick pline")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) (princ co-ord) Quote Link to comment Share on other sites More sharing options...
