Kvlar Posted June 9 Share Posted June 9 I found autolisp code on this forum with the function of inserting multiple blocks at the center point circle. Can anyone help me to make a code like this but with function to inserting multiple blocks (Attribute Blocks) at the geometric center of a closed polyline Thank you This is the code for inserting multiple blocks at the center point circle : BlockOnCircle.lsp Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 9 Share Posted June 9 Like this ? (setq cpt (osnap (vlax-curve-getStartPoint obj) "gcen")) Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 10 Share Posted June 10 also mid point of bounding box of entity ;obj = vla-object name (vla-getboundingbox obj 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) ) Quote Link to comment Share on other sites More sharing options...
Kvlar Posted June 11 Author Share Posted June 11 Thank you to all of you Quote Link to comment Share on other sites More sharing options...
