... & it only took 24hrs to go... erm... full circle :D
  • Replies 28
  • samson
    9
  • CarlB
    3
  • Tiger
    3
  • Hedgehog
    3
Posted Images
  CarlB said:
You're welcome, glad to help. SLW210's method also works, although mine follows (my) thought process.
I often use your method as well CarlB, I just thought that method might be easier for Samson to follow. If I find the time I will try to do a drawing using CarlB's method for any future Caddies with this problem. :thumbsup:
  samson said:
Thanks for the effort Beammeup but no, I need the arc the opposite way around. See attached, This is the one I drew a while ago but as I have an exam coming I thought i`d do it again to refresh my memory. Lost all confidence now though. Thanks again.
One thing to note here: why have you used a scale of 3:1 ?
that is not a scale that appears on any scale rule (triangular or otherwise) that i have ever seen.
consider using 2:1 or 5:1 ?
Thanks NBC, scale was on the drawing in the exercise book so copied it as it said. Sorry for delay in reply but didn`t notice it. Cheers for your help again.
  • 1 year later...
  samson said:
Hi,
ACAD 2008, I`m Having all sorts of problems trying to draw an arc joined to a circle. I have got it to work once but can`t seem to do it again. Is it possible I have something active which is stopping the snap to Tan. Everytime I try it, the snap seems to be in a different position.
Hi Samson
Looks like I have the same problem. I just carried out the same search while working through the C&Gs 4353 award assignment 1. and can't work it out how to do it properly. Did you suss it out in the end. I'm the tutor and I can work it out!!
Sean
  sean said:
Hi Samson
Sean
sean - first off, please don't add a new question to existing thread, for best result start a new thread for each new question.
Second - from this thread it looks like Samson got his question answered in this thread, does any of the solutions offered solve your problem?
If it doesn't, please start a new thread and describe your problem in more detail and we'll see if the Forum can help you.
Offset the circle 30, draw a circle from the line with radius 30, use the intersection of the two circles as the center of the arc. Or draw a circle from there and trim.
Thanks guys for all your help. I think I understand how to do it now. Ta Sean
