Alexia Posted June 7, 2024 Posted June 7, 2024 Hello, Does anyone have a lisp routine to quickly create curb lines? I'm looking for a LISP that can be done in one command line and two clicks: 1. Request to select a polyline and change it to P-PVMT-FOC layer 2. Ask to click in a direction above or below the first line, create a new polyline with a 0.5' offset and move this new line to P-PVMT-BOC 3. Create another polyline in the opposite direction from the second one with a 1.5' offset from the initial FOC line and move it to P-PVMT-EOP layer. To summarize: BOC -0.5- FOC -----1.5'----- EOP Thanks a lot!!! Quote
f700es Posted June 7, 2024 Posted June 7, 2024 Here is a free set of Civil cad tools that might be of some use. I'm not sure if there was any curb tools there. https://www.glamsen.se/CadTools.htm Quote
ronjonp Posted June 7, 2024 Posted June 7, 2024 @Alexia Give this a try: (defun c:foo (/ _lyr s) ;; RJP » 2024-06-07 (defun _lyr (e l) (entmod (append (entget e) (list (cons 8 l))))) (cond ((setq s (ssget ":L" '((0 . "LWPOLYLINE")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (_lyr e "P-PVMT-FOC") (and (setq p (getpoint "\nPick 0.5 offset side")) (command "_.offset" 0.5 e p "")) (_lyr (entlast) "P-PVMT-BOC") (and (setq p (getpoint "\nPick 1.5 offset side")) (command "_.offset" 1.5 e p "")) (_lyr (entlast) "P-PVMT-EOP") ) ) ) (princ) ) Quote
BIGAL Posted June 8, 2024 Posted June 8, 2024 (edited) Another method, if you pick a pline and want fixed offsets a simple trick is pick near start end, this can give direction of pline then use VLA-Offset will go left or right then automatically. ; change single pline to multiple ; By AlanH June 2024 (defun c:drawcurb ( / off1 off2 ent pt obj start end d1 d2 obj2 ent2) (command "-layer" "m" "P-PVMT-FOC" "C" 1 "" "M" "P-PVMT-BOC" "C" 2 "" "m" "P-PVMT-EOP" "C" 3 "" "") ; added in case layers don't exsit (setq off1 0.5 off2 1.5) (setq ent (entsel "\nPick pt near start of pline ")) (setq pt (cadr ent)) (setq obj (vlax-ename->vla-object (car ent))) (setq start (vlax-curve-getstartPoint obj)) (setq end (vlax-curve-getendPoint obj)) (setq d1 (distance pt start)) (setq d2 (distance pt end)) (if (< d1 d2) (command "Pedit" ent "R" "") ) (setq ent2 (entget (car ent))) (entmod (subst (cons 8 "P-PVMT-FOC") (assoc 8 ent2) ent2)) (setq obj2 (vla-offset obj off1)) (setq ent2 (entget (entlast))) (entmod (subst (cons 8 "P-PVMT-BOC") (assoc 8 ent2) ent2)) (setq obj2 (vla-offset obj off2)) (setq ent2 (entget (entlast))) (entmod (subst (cons 8 "P-PVMT-EOP") (assoc 8 ent2) ent2)) (princ) ) (c:drawcurb) Ps if I have side wrong change change (> d1 d2) Edited June 8, 2024 by BIGAL Quote
Craig Rathke Posted November 9, 2025 Posted November 9, 2025 @BIGAL You lisp works very well, but I spend alot of time having to delete offsets if I'm not sure where the true start of line is....especially with close polylines. It will always seems to offset the wrong direction and I end up having to reverse the original closed polyline. (FYI I am trying to use a slightly altered version of your code, using a -0.5' offset for the back of curb since I want to offset to both sides based on the initially drawn face of curb for parking lots.) Is there any way the code can be altered in this way: Instead of selecting the beginning point of the object, you just select the object normally, then it prompts you to select the side of the back of curb (in your code, that would be the off1) and then I get an offset to both sides of the selected line..a BOC (off1) and an EOP (off2). This adds an extra click but makes sure I offset the correct direction. I'm not sure how to begin to do this. Any help would be appreciated. Thanks!!! -Craig On 6/7/2024 at 8:19 PM, BIGAL said: Another method, if you pick a pline and want fixed offsets a simple trick is pick near start end, this can give direction of pline then use VLA-Offset will go left or right then automatically. ; change single pline to multiple ; By AlanH June 2024 (defun c:drawcurb ( / off1 off2 ent pt obj start end d1 d2 obj2 ent2) (command "-layer" "m" "P-PVMT-FOC" "C" 1 "" "M" "P-PVMT-BOC" "C" 2 "" "m" "P-PVMT-EOP" "C" 3 "" "") ; added in case layers don't exsit (setq off1 0.5 off2 1.5) (setq ent (entsel "\nPick pt near start of pline ")) (setq pt (cadr ent)) (setq obj (vlax-ename->vla-object (car ent))) (setq start (vlax-curve-getstartPoint obj)) (setq end (vlax-curve-getendPoint obj)) (setq d1 (distance pt start)) (setq d2 (distance pt end)) (if (< d1 d2) (command "Pedit" ent "R" "") ) (setq ent2 (entget (car ent))) (entmod (subst (cons 8 "P-PVMT-FOC") (assoc 8 ent2) ent2)) (setq obj2 (vla-offset obj off1)) (setq ent2 (entget (entlast))) (entmod (subst (cons 8 "P-PVMT-BOC") (assoc 8 ent2) ent2)) (setq obj2 (vla-offset obj off2)) (setq ent2 (entget (entlast))) (entmod (subst (cons 8 "P-PVMT-EOP") (assoc 8 ent2) ent2)) (princ) ) (c:drawcurb) Ps if I have side wrong change change (> d1 d2) Quote
alanjt Posted November 17, 2025 Posted November 17, 2025 See attached. It does not set layers, but I use this to generate curb offsets, based on multiple selected lines/etc. OffsetMultiple.lsp 1 Quote
Craig Rathke Posted November 17, 2025 Posted November 17, 2025 Nice. Thank you! I might be able to use this idea and tweak it with layer. Quote
BIGAL Posted November 17, 2025 Posted November 17, 2025 Nice @alanjt. Have you thought about using a Mline you can set the offsets and layers. If it's wrong flip line. In a lisp can reverse lines, plines and mlines. The other thing of course is offset 3d line work, including +- to rl's. Quote
alanjt Posted November 20, 2025 Posted November 20, 2025 On 11/17/2025 at 4:37 PM, BIGAL said: Nice @alanjt. Have you thought about using a Mline you can set the offsets and layers. If it's wrong flip line. In a lisp can reverse lines, plines and mlines. The other thing of course is offset 3d line work, including +- to rl's. I thought about using MLines, but decided against it because once I offset, I'm generally modifying to draw in curb ramps, etc. I've considered using different layers, but I've never been able to get other people on board. Might be time to give it another attempt. For grading, I have a separate program I wrote that creates my featureline curb offsets based on a selected featureline. Quote
BIGAL Posted November 20, 2025 Posted November 20, 2025 @alanjt are you still using civ3d2013 ? I have for a few years now used Civil Site Design running under CIV3D and Bricscad, it has some great road designing tools, when you define the road shape and do a design the kerbs can then be drawn into the plan, this includes where intersections are involved the kerbs being drawn automatically around the curves. Plus of course wandering kerb lines. Maybe have a look. Quote
alanjt Posted November 25, 2025 Posted November 25, 2025 On 11/20/2025 at 5:14 PM, BIGAL said: @alanjt are you still using civ3d2013 ? I have for a few years now used Civil Site Design running under CIV3D and Bricscad, it has some great road designing tools, when you define the road shape and do a design the kerbs can then be drawn into the plan, this includes where intersections are involved the kerbs being drawn automatically around the curves. Plus of course wandering kerb lines. Maybe have a look. No. I need to update. We're currently on c3d2024. I'm curious, what is "civil site design"? Is this a separate addon? I use corridors, intersections, etc. for roadway design. However, I haven't found anything better for site design than featurelines. If I am missing something, please educate me. Quote
BIGAL Posted November 25, 2025 Posted November 25, 2025 (edited) Yes Civil Site Design is a full Civil design package, Surfaces, Roads, Gradings, Drainage and Sewerage. It is sold world wide, in particular in available for CIV3D and Bricscad. They do a OEM Acad as well. https://civilsitedesign.com.au/ There is numerous YouTube videos showing features and how to's. https://www.youtube.com/@CivilSurveyApplications If you have a particular design task let me know I can make enquiries for you, but they are very helpful. I have known the Director for like 40 years so its a product that has that type of on going improvement history. It uses much more intelligent DCL's for data input than CIV3D. Look at the Youtubes. Edited November 25, 2025 by BIGAL Quote
