jaconbue Posted March 18, 2009 Posted March 18, 2009 I've just finished to develop a code to print all layouts in all cad drawing files existing in a specified folder, with some user entered options (printer, paper size, plot style). SCHEMA First, a dos batch script to load AutoCAD, open a special CAD drawing and load a SCR (AutoCAD Script File). Second, the AutoCAD Script File loads a Visual Basic Macro inside the file. Third, the Macro ask the user to enter some information, opens all files within a folder, and plots all layouts inside the files, with the user entered options. When it finishes, it closes all files, and SCR closes AutoCAD. DOS BATCH SCRIPT [iMPRIMELOTE.BAT] @echo off break on cls title Impresi¢n por lotes en AutoCAD echo. echo. echo Iniciando AutoCAD... echo. echo. if exist "%programfiles%\Autocad 2004\acad.exe" set CAD="%programfiles%\Autocad 2004\acad.exe" if exist "%programfiles%\Autocad 2005\acad.exe" set CAD="%programfiles%\Autocad 2005\acad.exe" if exist "%programfiles%\Autocad 2006\acad.exe" set CAD="%programfiles%\Autocad 2006\acad.exe" %CAD% %~dps0ImprimeLote.dwg /b %~dps0ImprimeLote.scr exit AUTOCAD SCRIPT [iMPRIMELOTE.SCR] _-vbarun Módulo1.ImprimeLote _qsave _quit VISUAL BASIC MACRO [MÓDULO1.IMPRIMELOTE] Public Sub ImprimeLote() Dim numPresentaciones As Integer Dim numArchivos As Integer Dim respuesta As Variant Dim Impresora As String Dim Papel As String Dim Ancho As Double Dim AnchoPredet As Double, AltoPredet As Double Dim Escala As Double Escala = 1 Dim n As Double, d As Double Dim Plumilla As String Dim fs, f, f1, fc, s Set fs = CreateObject("Scripting.FileSystemObject") numArchivos = Application.Documents.Count 'Introduzco datos respuesta = InputBox("Introduzca la ruta de la carpeta" & Chr(10) & _ "(completa, incluyendo letra de unidad)", "Impresión por lotes") If respuesta "" Then If fs.folderexists(Carpeta) Then Carpeta = respuesta Else MsgBox "Error: No existe la carpeta", vbApplicationModal, "Impresión por lotes" End End If Else End End If respuesta = InputBox("Introduzca el nombre de la impresora" & Chr(10) & _ "(debe coincidir con el nombre guardado en AutoCAD)", "Impresión por lotes") If respuesta "" Then Impresora = respuesta Else End End If respuesta = InputBox("Introduzca el tamaño del papel" & Chr(10) & _ "(debe coincidir con el de AutoCAD, por ejemplo ISO A3)", "Impresión por lotes") If respuesta "" Then Papel = respuesta Else End End If respuesta = InputBox("Introduzca el ancho del papel" & Chr(10) & _ "(en mm, servirá para ajustar la escala de impresión)", "Impresión por lotes") If respuesta "" Then Ancho = respuesta Else End End If respuesta = InputBox("Introduzca el nombre de la plumilla" & Chr(10) & _ "(archivo CTB para configurar la impresión)" & Chr(10) & _ "[.] para ninguna." & Chr(10) & _ "[en blanco] para usar la predeterminada.", "Impresión por lotes") If respuesta "" Then Plumilla = respuesta Else 'End Si el usuario lo deja en blanco, se usará el valor por defecto End If ' creo la lista de archivos Set f = fs.GetFolder(Carpeta) Set fc = f.Files For Each f1 In fc If Right(f1.Name, 3) = "dwg" Or Right(f1.Name, 3) = "DWG" Then ' abre el archivo Application.Documents.Open f1.Path ' extrae cuántas presentaciones hay numPresentaciones = Application.ActiveDocument.Layouts.Count ' voy activando presentaciones y las imprimo For i = 0 To numPresentaciones - 1 If Application.ActiveDocument.Layouts.Item(i).Name "Model" Then 'No imprimimos el modelo 'activo la presentación Application.ActiveDocument.SendCommand ("_layout" & vbCr & "_s" & vbCr & Application.ActiveDocument.Layouts.Item(i).Name & vbCr) 'fijo la escala Application.ActiveDocument.Layouts.Item(i).GetCustomScale n, d Escala = n / d Application.ActiveDocument.Layouts.Item(i).GetPaperSize AnchoPredet, AltoPredet If AnchoPredet >= AltoPredet Then respuesta = AnchoPredet Else respuesta = AltoPredet End If 'sólo contemplo la posibilidad de trabajar en ISO A4, A3 o A1 Select Case Ancho / (respuesta + '8 mm de margen de impresión Case Is > 2.4142 'A4->A1 Escala = Sqr(2) * 2 * Escala Case Is > 1.7071 'A3->A1 Escala = 2 * Escala Case Is > 1.2071 'A4->A3 Escala = Sqr(2) * Escala Case Is > 0.8536 'Sin cambios Escala = 1 * Escala Case Is > 0.6036 'A3->A4 Escala = Sqr(2) / 2 * Escala Case Is > 0.4268 'A1->A3 Escala = 0.5 * Escala Case Else 'A1->A4 Escala = Sqr(2) / 4 * Escala End Select 'simple (no cambia tamaño de papel ni escala, toma opciones por defecto) 'Application.ActiveDocument.SendCommand ("_-plot" & vbCr & "_n" & vbCr & Application.ActiveDocument.Layouts.Item(i).Name & vbCr & vbCr & Impresora & vbCr & "_n" & vbCr & "_y" & vbCr & "_y" & vbCr) 'detallada Application.ActiveDocument.SendCommand ("_-plot" & vbCr & "_y" & vbCr & Application.ActiveDocument.Layouts.Item(i).Name & vbCr & Impresora & vbCr & Papel & vbCr & "_m" & vbCr & "_l" & vbCr & "_y" & vbCr & "_e" & vbCr & CStr((1000000 * Escala) \ 1000000) & "." & CStr((1000000 * Escala) Mod 1000000) & vbCr & "_c" & vbCr & "_y" & vbCr & Plumilla & vbCr & vbCr & vbCr & vbCr & vbCr & vbCr & "_y" & vbCr & "_y" & vbCr) End If Next 'guardo y cierro el archivo Application.ActiveDocument.SendCommand ("_qsave" & vbCr & "_close" & vbCr) While Application.Documents.Count numArchivos 'espero a que se cierre, para no tener muchos archivos abiertos DoEvents Wend End If Next End Sub ADITIONAL COMMENTS This 3 files must be in the same folder, but not neccesary to be the folder in which there are the CAD drawings to plot. If user types incorrectly the data, macro will fall. Macro would run faster if virus macro protection is disabled. If the files are configured to plot in a ISO A1 but we need to plot a reduction on ISO A3, macro will change plot scale accordingly. The macro uses "Plot Extension" and "Plot page centered". All other plot options are chosen by default. The macro prevents AutoCAD to open too many files, waiting for a while to close each file when it finishes with it. Plot configuration changes are saved in each file, so, at the end, all files are configured to the same printer, the same paper size and the same plot style. It's similar to the use of PUBLISH command, with some minor advantages. It is possible to use this code into a VBP file and load it when AutoCAD starts, making possible to use the macro whenever you want. You can customize palette buttons creating a new user-defined button to run this macro. I apologize for my english: I'm spanish. I hope it would be useful for someone. Bye! ImprimeLote.zip Quote
VVA Posted March 18, 2009 Posted March 18, 2009 Or use Terry Miller's PlotDwgs PlotDwgs is a plot utility program with several unique options including plotting all open drawings, and plotting a folder of user selected drawings. Drawings may be plotted to a specified size, or by selecting the "Varies" option, the program determines the correct paper size to plot. Also included is the option of plotting all layouts in reverse order, and plotting a folder of user selected drawings in reverse order. The associated files are PlotDwgs.lsp, PlotDwgs.dcl and PlotDwgs.dvb. Quote
jaconbue Posted March 23, 2009 Author Posted March 23, 2009 Hi. In my own Visual Basic Macro as well as in Terry Miller's PlotDwgs is neccesary to translate many localized commands (if you use a localized version of AutoCAD). For example, "-PLOT" (english) may be replaced by "-TRAZADOR" (spanish). Some answers in command line, like "Y" (yes) should be replaced by "S" (s Quote
VVA Posted March 24, 2009 Posted March 24, 2009 There is no necessity to translate the name of English commands in names of commands of the localised versions. There is enough before English commands and english options to use a prefix "_" For example: (command "[color="Red"]_[/color]PSPACE") (command "[color="Red"]_[/color]LINE" "0,0" "10,0" "10,10" "[color="Red"]_[/color]C") (command "[color="Red"]_[/color]-PLOT" "[color="Red"]_[/color]Y" ...) Quote
Lee Mac Posted March 24, 2009 Posted March 24, 2009 There is no necessity to translate the name of English commands in names of commands of the localised versions. There is enough before English commands and english options to use a prefix "_"For example: (command "[color=Red]_[/color]PSPACE") (command "[color=Red]_[/color]LINE" "0,0" "10,0" "10,10" "[color=Red]_[/color]C") (command "[color=Red]_[/color]-PLOT" "[color=Red]_[/color]Y" ...) Also see here for help on this topic. Quote
jaconbue Posted March 25, 2009 Author Posted March 25, 2009 Thanks for those comments. I 've reviewed my code and parse accordingly. New version in first post. Bye! Quote
