Pulkit saini Posted May 25 Share Posted May 25 Hi I am using autoCAD civil 3D. But from few days I am using tcount command and it is not executing properly as I want number series increasing by 1 but is increasing by 2. Any suggestions will help me to improve my work. Also I am applying this command on Mtext. Thank you. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted May 28 Share Posted May 28 The count option only asks for start and increment. It doesn't show the current value, it just gives you the option. What has probably happened is that you changed the count to 2. If it showed you the current count, you would see it immediately. Try entering a count of 1. See this page if it's not clear. Quote Link to comment Share on other sites More sharing options...
