Shib Sankar Posted May 24 Share Posted May 24 Can anyone help me to write a code ?? Which Identifies each closed polyline (rectangle) on the "ss-bor" layer. Finds the text entity (content) of text on the "ss-pre" layer which is within (rectangle) on the "ss-bor" layer . Selects all entities on the "ss-part" layer within the (rectangle) on the "ss-bor" layer. Creates a block using the text value from the "ss-pre" layer as the block name, including all selected entities from the "ss-part" layer within the (rectangle) on the "ss-bor" layer. and loop though each (rectangle) on the "ss-bor" layer and make block of each as above mentioned.. For information i have attached my dwg file G27.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 25 Share Posted May 25 (edited) Do you know much about lisp ? 1st returns 8 entities in your dwg as you have before and after remove "X" if you want to select dwg area objects. (setq ss (ssget "X" '((0 . "LWPOLYLINE")(cons 8 "ss-bor")(cons 410 (getvar 'ctab))))) Loop through ss and get co-ordinates of each rectang. (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) Then get the text with another ssget, it should only get 1 then retrieve Text string (setq ss2 (ssget "CP" co-ords '((0 . "TEXT")"(cons 8 "ss-pre")(cons 410 (getvar 'ctab))))) Then get line work (setq ss3 (ssget "CP" co-ords '((0 . "*LINE")"(cons 8 "ss-part")(cons 410 (getvar 'ctab))))) Then make block using ss3. Continue looping till end. This is just sequence not a full program. Edited May 25 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
