itacad Posted May 24 Share Posted May 24 Good morning, I found the explanation of the subject variable of the topic FILETABPREVIEW https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-BE2D28F6-C85C-4EA1-9D39-478C27200EE2 0 = Displays a list that includes Model and all layout names. 1 = Displays a set of thumbnail images. I ask you if there is an additional setting that allows me not to display "a list that includes Model and all layout names either" When I casually pass over it with the mouse, this window opens which is not useful to me at all... I would like to see nothing Thank you Quote Link to comment Share on other sites More sharing options...
tombu Posted May 25 Share Posted May 25 Take a look at the system variable FILETABTHUMBHOVER https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-15DD5C80-C8C8-4750-87C0-0C67A975FB79 Specifies whether the corresponding model or layout loads in the drawing window when you hover over a file tab thumbnail. Value Description 1 Loads the model or layout in the drawing window when you hover over a file tab thumbnail. 0 Does not load the model or layout in the drawing window when you hover over a file tab thumbnail. or just turn off the FILETABSTATE if you're not using them like I do to get more drawing area on the screen. https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-3C8E04C4-D464-4615-A9FB-68FB28487723 Quote Link to comment Share on other sites More sharing options...
itacad Posted May 27 Author Share Posted May 27 Hello and thank you in the meantime. I already knew the variables you indicated and I'm using them (apart from FILETABSTATE which strangely I see indicated as read-only main past it seems to me that it could be set) What I would like is not to display this window on mouse hover. It's possible? Quote Link to comment Share on other sites More sharing options...
