KraZeyMike Posted May 24 Share Posted May 24 Almost every drawing I work on is exported from another Survey program and then Imported into Civil3D as a DXF I have sped up this process with a Lisp command and built in AutoCAD functions but would really like to combine the whole process into one Command. I am not sure if I can modify and combine existing lisps to achieve this or using a Script which I have had no experience with as yet. Below I have outlined the steps, attached the Lisp used and a video (two parts due to size limit) outlining the process that for every job is becoming tiresome. Redefine the inserted Block For some reason when I insert the DXF it does not automatically redefine (Which is needed to update Survey blocks to my custom Acad Blocks. So I have to re-insert the DXF to force redefine "DP" Lisp (Attached) - This routine deletes the crosses that are carried over from our Survey Software and are not required. Explode and set "By Layer" Color, Linetype and Lineweight Attsync two blocks - POINT_CROSS and $FILL Finally I would like to select the Attsync selection (POINT_CROSS and $FILL) and set their scale back to 1 Seems to be that these blocks which I have redefined to be annotative, scale according to the model space when inserted which we don't leave on 1:1 but our most commonly used scales for each template. As always the expertise and help provided here is greatly appreciated. Part One - DXF into Civil3D.mp4 DP (Delete Points).lsp Quote Link to comment Share on other sites More sharing options...
KraZeyMike Posted May 24 Author Share Posted May 24 Part Two - DXF into Civil3D - Trim.mp4 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 24 Share Posted May 24 Is the dxf from Magnet or Civilcad ? Have something. Quote Link to comment Share on other sites More sharing options...
KraZeyMike Posted May 24 Author Share Posted May 24 It is from Magnet Office Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 25 Share Posted May 25 Not sure if this will help. I am ex Civilcad State Rep many years ago. It does quite a few things to a Magnet dwg. Try it and let me know how you go. Ps I am in AUS near Newcastle. convccad.LSP civilcad6LAYERCODES.txt Quote Link to comment Share on other sites More sharing options...
KraZeyMike Posted May 27 Author Share Posted May 27 Thanks BIGAL, I got it to work but it's not really what I am after. My main gripe is having to re-insert all the time to redefine the POINT_CROSS blocks with my own inside the drawing, then of course having to attsync and set the scales back to one etc. Basically the process in the video above. Most of the other items I have separate lisp routines for depending on if they are required or not. I forgot to add a third Magnet block that I always have to redefine is POINT_SCIRCLE which we use for invert levels (Again redefined to my own block). I'm still not sure why I have to re-insert for a Magnet DXF to redefine to my custom blocks, inserting from the design centre always prompts to redefine first go. Ps. Also from AU, NSW. My Brother-in-law is working on the Hexham Straight upgrade Quote Link to comment Share on other sites More sharing options...
KraZeyMike Posted May 28 Author Share Posted May 28 (edited) From my limited (very limited) knowledge of lisp routines. I'm thinking the solution would be to insert as per normal and then begin the lisp with either a reinsert previous (to prompt the redefine) or a redefine function prompting me to select the dxf block. This would ideally flow onto the DP lisp attached to remove the pd mode crosses and then an explode command. After that maybe a Sel1 or Setq 1st for the blocks "POINT_CROSS,$FILL,POINT_SCRICLE" and run the attsync function; followed by the same selection set and set Scale X of the blocks to 1. Finally it would finish with a Ctrl All to set Color, Linetype and Lineweight to By Layer. I can seem to find pieces of all these functions but can't put it all together Edited May 28 by KraZeyMike Quote Link to comment Share on other sites More sharing options...
