Attribute Extraction To txt - Re-order
I have found a Lisp program on this forum by Miklos Fuccaro (thanks) that is very close to what I need, I have modified it slightly but still have one problem. The Lisp outputs the attributes of named blocks to a text file for importing into label printing software which is what I need but the strings of text seperated by commas need to be in a column instead.
i.e. a,b,c,d should be
a
b
c
d
I need to have any blank attributes retained so they will result in a blank row.
Here is the code:
; Global ATTribute EXtractor
; by Miklos Fuccaro [email="mfuccaro@hotmail.com"]mfuccaro@hotmail.com[/email]
;-------------------------November 2004 -------
;;Edited March 2006 by C. Bassler to allow specification of block and tage names to extract
;;Modified March 2009 by B.Leslie to write Attributes only and name txt file with DWG filename.
(defun gattex()
  (setq Blocklist '("Name1" "Name2" "Name3"));; ** edit to include block names to select
  (setq TagList '("Tag1" "Tag2" "Tag3"));; ** edit to include tag names to extract
  ;;create block names separated by columns, for selection filter
  (setq Blocknames (List2String BlockList))
  (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 BlockNames))))
  (if (not ss) (quit))
  (setq Root (getvar "DWGPREFIX"))
  (setq file (open (strcat "F:\\ENGINEER\\GENERIC\\Label Schedule\\Extracted Labels\\MK_Equipment_" (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname"))4)) ".TXT") "a") i -1)
  (repeat (sslength ss)
      (setq Edata (entget (setq e (ssname ss (setq i (1+ i))))))
      (while (/= (Dxf 0 Edata) "SEQEND")
         (if
             (and
                 (= (Dxf 0 Edata) "ATTRIB")
                 (member (dxf 2 Edata) TagList);;if tag is on list
             );and
                 (setq valRow (cons (Dxf 1 Edata) ValRow))
             );progn
         (setq Edata (entget (setq e (entnext e))))
      );while
      (write-line (List2String (reverse ValRow)) file)
  );repeat
  (close file)
  (princ (strcat "\nDone writing file " Root "MK_Equipment.txt"))
);defun
(defun List2String (Alist)
  (setq NumStr (length Alist))
     (foreach Item AList
        (if (= Item (car AList));;first item
           (setq LongString (car AList))
           (setq LongString (strcat LongString "," Item))
  LongString
);defun
(defun Dxf (code pairs)
  (cdr (assoc code pairs))
(gattex)
Thanks for any help.
Bryan
Untested, but give this a go:
; by Miklos Fuccaro mfuccaro@hotmail.com
(defun gattex()
         (if
             (and
             );and
             );progn
      );while
      (foreach v (reverse ValRow) (write-line v file))
  );repeat
  (close file)
);defun
     (foreach Item AList
  LongString
);defun
(gattex)
Thanks Lee that works a treat apart from it keep repeating and I get the same data about 30 times.
I think that's because the variables aren't localised - but I may consider just writing another one, because the repeat method can't handle selection sets greater than 32767 entities.
Try this, again - untested:
(defun c:gattex2 (/ Blklst Tglst ss file aEnt)
 (setq Blklst '("Name1,Name2,Name3") Tglst '("Tag1" "Tag2" "Tag3"))
 (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 Blklst) (cons 66 1))))
           (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname"))4)) ".txt") "a"))
     (foreach Ent (mapcar 'cadr (ssnamex ss))
   (setq aEnt (entnext Ent))
   (while (/= "SEQEND" (cdadr (entget aEnt)))
     (if (member (cdr (assoc 2 (entget aEnt))) Tglst)
       (write-line (cdr (assoc 1 (entget aEnt))) file))
     (setq aEnt (entnext aEnt))))
     (close file))
   (princ "\n<!> No Blocks Found <!>"))
 (princ))
Get this error when run - ; error: bad SSGET list value
My goodness, this really isn't my day today! :)
 (setq Blklst "Name1,Name2,Name3" Tglst '("Tag1" "Tag2" "Tag3"))
     (close file))
 (princ))
I think I should go back to bed :oops:
That did the trick, you can go back to bed and sleep easy now.:)
Thank you very much for your help.
