Leeboy Posted May 23, 2024 Posted May 23, 2024 the file was send to me in exploded, is there any type of key to turn it back to its original form? thanks Quote
SLW210 Posted May 23, 2024 Posted May 23, 2024 Welcome to CADTutor!! That's not much information to go on. Can you post a .dwg and explain in more detail what's going on? Quote
CyberAngel Posted May 23, 2024 Posted May 23, 2024 Welcome to the forum! What kind of leftovers do you have? Contours? 3D faces? Points? Since you're on Civil 3D, you should be able to rebuild the surface with those. That doesn't help with profiles or corridors, though. The first strategy, of course, is to ask for the unexploded version, but I guess you tried that already. Seems like it would be a lot easier for them to remove whatever they don't want you to have than for you to restore all that lost information. But some companies are like that. Quote
BIGAL Posted May 24, 2024 Posted May 24, 2024 If your paying for the dwg file then insist that you get what you want, not what they want to give you. If not get another contractor. We supplied a CIV3D file and surface 3dfaces if they were using non CIV3D. 1 Quote
