3dwannab Posted May 23 Share Posted May 23 (edited) Hi all, Here's the code I have to hatch items inside blocks with a wipeout layer. Handy for furniture and the like. I was wondering if there was a more robust way of selecting objects in the block editor to hatch them. See line: (setq ssObj2Hat (ssget "_X" '((0 . "~*TEXT") (0 . "~ATTDEF")))) ;; Select all but TEXT, MTEXT or ATTDEF (Testing) I've removed all text and attributes because they're those objects I would like to remove. I'd like to get your guys thoughts on how best to tackle this, thanks. If nothing else share this with you all (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; BK_Hatch_Solid_With_Wipeout.lsp ;; Hatches objects inside blocks with a SOLID hatch and on the "GN_wipe-out" layer. ;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Based on code by Tharwat 18th Sept 2013 ;; https://www.cadtutor.net/forum/topic/46782-deleting-hatch-from-blocks/?do=findComment&comment=396412 ;; ;; First modified on 2022.12.12 by 3dwannab to hatch everything inside the block. Help over here: https://www.cadtutor.net/forum/topic/76450-hatch-objects-inside-a-block/ ;; Last modified on 2024.05.22 by 3dwannab ;; ;; Requires the _createOrUpdateLayer function located in the acaddoc.lsp file. ;; ;; TO DO: Only hatch entities that can be hatched. Think there may be a vla-get for this. Not sure. ;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:BKHatch_Solid_With_Wipeout (/ *error* acDoc blkn cnt i layerName obj ssHatches ssIns ssObj2Hat var_cmdecho var_osmode) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) (setvar 'osmode var_osmode) ) ;; Start the undo mark here (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) ;; Get any system variables here (setq var_cmdecho (getvar "cmdecho")) (setq var_osmode (getvar "osmode")) (setvar 'cmdecho 0) (setvar 'osmode 0) (setq layerName "GN_wipe-out") (prompt (strcat "\nSelect BLOCKS to solid hatch in the layer '" layerName "' :\n")) (if (setq ssIns (ssget "_:L" '((0 . "INSERT")))) (progn (setq cnt 0) (repeat (setq cnt (sslength ssIns)) (setq cnt (1- cnt)) (setq blkn (cons (vla-get-effectivename (vlax-ename->vla-object (_dxf -1 (entget (ssname ssIns cnt))))) blkn)) ) (setq blkn (_removedup blkn)) (foreach x blkn (command "-bedit" x) (setvar 'cmdecho 0) ; Set this inside block editor just in case. (setvar 'osmode 0) ; Set this inside block editor just in case. (setq ssHatches (ssadd)) ; (setq ssObj2Hat (ssget "_X" '((0 . "LWPOLYLINE") (-4 . "<OR") (70 . 1) (70 . 129) (-4 . "OR>")))) ;; Select closed polylines (setq ssObj2Hat (ssget "_X" '((0 . "~*TEXT") (0 . "~ATTDEF")))) ;; Select all but TEXT, MTEXT or ATTDEF (Testing) (if ssObj2Hat (progn ;; Create the wipe out layer (_createOrUpdateLayer layerName '(254 254 254) "Continuous" acLnWt025 0 :vlax-true "Craftstudio Layer - General Layer: Useful for furniture and other movable objects to obscure whats behind") (command "_.-hatch" "_P" "_S" "_LA" "." "_advanced" "_associativity" "_yes" "" "_select" ssObj2Hat "" "") ;; Add the created hatches to a selection set. (setq ssHatches (ssadd (entlast) ssHatches)) ;; Loop through selected objects and set properties (repeat (setq i (sslength ssHatches)) (setq obj (vlax-ename->vla-object (ssname ssHatches (setq i (1- i))))) ;; Set the hatch objects to the correct properties for the 'GN_wipe-out' layer. (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Layer (list obj layerName))) (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Linetype (list obj "ByLayer"))) (vla-put-LineWeight obj aclnwtbylayer) (vla-put-Color obj acbylayer) (vla-put-LinetypeScale obj 1) (vla-put-EntityTransparency obj "ByBlock") ) ;; Send behind the selected objects. (command "_.draworder" ssHatches "" "_U" ssObj2Hat "") ) ) ; if ssObj2Hat (command "_.bsave") (command "_.bclose") (redraw) ) ; foreach ) ; progn ) (if ssIns (progn (princ (strcat "\n: ------------------------------\n\t\t<<< " (itoa (sslength ssIns)) (if (> (sslength ssIns) 1) " <<< BLOCKS" " <<< BLOCK") " solid hatched with layer '" layerName "'\n: ------------------------------\n")) (sssetfirst nil ssIns) (command "_.regen") ) ) (vla-EndUndoMark acDoc) (*error* nil) (princ) ) ;; removes duplicate element from the list (defun _removedup (l) (if l (cons (car l) (_removedup (vl-remove (car l) (cdr l)))) ) ) ;;----------------------------------------------------------------------;; ;; _dxf ;; Finds the association pair, strips 1st element ;; args - dxfcode elist ;; Example - (_dxf -1 (entget (ssname (ssget) 0))) ;; Returns - <Entity name: xxxxxxxxxxx> (defun _dxf (code elist) (cdr (assoc code elist)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; _createOrUpdateLayer ;; ;; Creates a new layer or updates an existing one if it exists. ;; Will attempt to load the linetype if found in the acad*.lin file and if the layer exists, it will update the properties. ;; Original code by ronjonp, taken from: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-layer-with-true-color-in-lisp/m-p/7904814#M367339 ;; ;; USAGE: ;; (_createOrUpdateLayer "Test1" 22 "Dashed" aclnwtbylwdefault 33 :vlax-true "Test1 Description") ;; (_createOrUpdateLayer "Test2" '(100 150 200) "Continuous" aclnwtbylwdefault 33 :vlax-false "Test2 Description") ;; ;; The :vlax-true or :vlax-false in examples above is for plot on or off. ;; The 33 values represent the transparency of the layer. ;; Original help from mhupp here to get it to update layer if it exists: https://www.cadtutor.net/forum/topic/75414-defun-to-create-or-update-layers-not-updating-them/?do=findComment&comment=596266 ;; ;; ARGUMENTS: ARGUMENTS SYTAX: ;; 1st arg: Layers Name = STRING ;; 2nd arg: Layers Colour = 22 or '(100 150 200) (Can be an indexed colour or true colour) ;; 3rd arg: Layers Linetype = STRING ;; 4th arg: Layers Lineweight = acLnWtByLayer, acLnWtByBlock, acLnWtByLwDefault, acLnWt000, acLnWt005, acLnWt009, acLnWt013, acLnWt015, acLnWt018, acLnWt020, acLnWt025, acLnWt030, acLnWt035, acLnWt040, acLnWt050, acLnWt053, acLnWt060, acLnWt070, acLnWt080, acLnWt090, acLnWt100, acLnWt106, acLnWt120, acLnWt140, acLnWt158, acLnWt200, acLnWt211 ;; 5th arg: Layers Transparency = INTEGER (Between 0-90) ;; 6th arg: Layers is Plottable on not = :vlax-true = Plottable or :vlax-false = Not Plottable ;; 7th arg: Layers Description = STRING ;; ;; For Linewiight in vlisp, see this reply by CAB: https://www.theswamp.org/index.php?topic=22438.msg270124#msg270124 ;; ;; MODIFICATIONS: ;; New code By Leemac with small modifications by 3dwannab. ;; Modified by 3dwannab on 2024.05.22 to add if the layers is plottable and also added the possibility to add a description to the layer. ;; Lee Macs code: https://www.cadtutor.net/forum/topic/66765-vla-put-truecolor/?do=findComment&comment=546879 ;; Modified by 3dwannab on 2024.05.22 to add transparency, description and plot to Lee Macs function. ;; Help from mhupp here to get it to update layer if it exists: https://www.cadtutor.net/forum/topic/75414-defun-to-create-or-update-layers-not-updating-them/?do=findComment&comment=596266 (defun _createOrUpdateLayer (name color linetype lineweight transparency plottable description / _loadlinetype lay tru) ;; Credit to Grr1337 ;; https://www.theswamp.org/index.php?topic=52473.msg574008#msg574008 ;; (_SetLayerTransparency (getvar 'clayer) 90) (defun _SetLayerTransparency (LayerName Transparency / lyr) (and (<= 0 Transparency 90) (setq lyr (tblobjname "LAYER" LayerName)) (not (setpropertyvalue lyr "Transparency" Transparency)) (not (entupd lyr)) ) ) (defun _loadlinetype (ltype / lt out) (cond ((tblobjname "ltype" ltype) t) ((setq lt (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object)))) (setq out (vl-catch-all-apply 'vla-load (list lt ltype (findfile (if (= 0 (getvar 'measurement)) "acad.lin" "acadiso.lin" ) ) ) ) ) (not (vl-catch-all-error-p out)) ) ) ) ;; defun _loadlinetype ;; Set the layer properties (setq lay (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) name)) ;; 1st arg (if (listp color) (progn (setq tru (vla-get-truecolor lay)) (apply 'vla-setrgb (cons tru color)) (vla-put-truecolor lay tru) ) (vla-put-color lay color) ;; 2nd arg ) (vla-put-linetype lay (if (_loadlinetype linetype) linetype "continuous" ) ) ;; 3rd arg (vla-put-lineweight lay lineweight) ;; 4th arg (_SetLayerTransparency name transparency) ;; 5th arg (vla-put-Plottable lay plottable) ;; 6th arg (vla-put-description lay description) ;; 7th arg lay ) ;; end _createOrUpdateLayer defun ; (c:BKHatch__Solid_With_Wipeout) Edited May 23 by 3dwannab 1 Quote Link to comment Share on other sites More sharing options...
