2004---Command line version of cancel? (As opposed to "Esc")
I'm writing a small script and I was wondering if there is a command line version of cancel? (Which I can currently access by using the "Esc" key
Thank you
I don't think there is.
You can look up a list of all the commands- go to Tools, Customize, Edit Program Parameters.
^C^C works in macros; I'm not sure about scripts.
it works in scripts, the reason for (2) ^C is in case you are in a transparent command (call it insurance)
  • 4 months later...
You can put (command) in your script file to cancel a command.
  • Agree 1
  • 4 years later...
Bingo! The (command) at the end of the script did the trick!
I'm updating The AutoCAD Workbench and I needed an answer to this question. Thank you!
