macros55 Posted September 5 Author Share Posted September 5 (edited) (vl-load-com) (mapcar '(lambda (x y / ) (if (not (tblsearch "LAYER" x)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 x) '(70 . 0) (cons 62 y) '(6 . "Continuous") '(290 . 1) '(370 . -3) ) ) ) ) '("H-Arrow" "H-Block" "H-Distance" "H-Elevation" "H-Line" "H-Slope") '(5 7 1 4 7 3) ) (if (not (tblsearch "STYLE" "Arial")) (entmake '( (0 . "STYLE") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "Arial") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.8) (3 . "arial.ttf") (4 . "") ) ) ) (if (not (tblsearch "LAYER" "H-Block")) (entmake '( (0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "H-Block") (70 . 0) (62 . 7) (6 . "Continuous") (290 . 1) (370 . -3) ) ) ) (if (not (tblsearch "BLOCK" "H-BLOCK")) (progn (entmake '((0 . "BLOCK") (2 . "H-BLOCK") (70 . 2) (4 . "") (370 . -2) (10 0.0 0.0 0.0))) (entmake '( (0 . "ATTDEF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "H-Distance") (100 . "AcDbText") (10 -2.82538 0.47 0.0) (40 . 0.8) (1 . "") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Arial") (71 . 0) (72 . 4) (11 0.0 0.87 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttributeDefinition") (280 . 0) (3 . "") (2 . "DISTANCE") (70 . 0) (73 . 0) (74 . 0) (280 . 1) ) ) (entmake '( (0 . "ATTDEF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "H-Arrow") (100 . "AcDbText") (10 -2.14106 -0.530273 0.0) (40 . 0.8) (1 . "") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Arial") (71 . 0) (72 . 4) (11 0.0 -0.13 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttributeDefinition") (280 . 0) (3 . "") (2 . "ARROW") (70 . 0) (73 . 0) (74 . 0) (280 . 1) ) ) (entmake '( (0 . "ATTDEF") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "H-Slope") (100 . "AcDbText") (10 -1.86357 -1.53027 0.0) (40 . 0.8) (1 . "") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Arial") (71 . 0) (72 . 4) (11 0.0 -1.13 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttributeDefinition") (280 . 0) (3 . "") (2 . "SLOPE") (70 . 0) (73 . 0) (74 . 0) (280 . 1) ) ) (entmake '((0 . "ENDBLK"))) ) ) (defun add_vtx (obj add_pt ent_name / bulg) (vla-addVertex obj (1+ (fix add_pt)) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 1)) (list (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) ) ) ) ) (setq bulg (vla-GetBulge obj (fix add_pt))) (vla-SetBulge obj (fix add_pt) (/ (sin (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) (cos (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) ) ) (vla-SetBulge obj (1+ (fix add_pt)) (/ (sin (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) (cos (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) ) ) (vla-update obj) ) (defun c:SAD1 ( / AcDoc Space n typ_ent sel l_z ss ent vla_obj d_start d_end pt_start pt_end len pt_mid deriv rtx OK old-dim arrow nw_obj l_pt l_blg pt_cen nw_pl) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (setq n 1 typ_ent nil) (repeat 2 (while (not (member typ_ent '("INSERT" "POINT" "CIRCLE"))) (setq sel (entsel (strcat "\nSelect insert " (itoa n) ": "))) (if sel (setq typ_ent (cdr (assoc 0 (setq dxf_ent (entget (car sel))))))) ) (setq l_z (cons (cdr (assoc 10 dxf_ent)) l_z) n (1+ n) typ_ent nil) ) (princ "\nSelect a curve object") (while (not (setq ss (ssget "_+.:E:S" '( (-4 . "<OR") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "<AND") (-4 . "<NOT") (-4 . "&") (70 . 1) (-4 . "NOT>") (-4 . "AND>") (-4 . "AND>") (0 . "ARC,LINE") (-4 . "OR>") ) ) ) ) ) (vla-startundomark AcDoc) (setq ent (ssname ss 0) vla_obj (vlax-ename->vla-object ent) l_z (mapcar '(lambda (y z) (list (car y) (cadr y) z)) (mapcar '(lambda (x) (vlax-curve-getClosestPointToProjection ent x (vlax-get vla_obj 'Normal))) l_z) (mapcar 'caddr l_z)) d_start (vlax-curve-getDistAtPoint ent (vlax-curve-getClosestPointTo ent (car l_z))) d_end (vlax-curve-getDistAtPoint ent (vlax-curve-getClosestPointTo ent (cadr l_z))) pt_start (if (> d_end d_start) (vlax-curve-getPointAtDist ent d_start) (vlax-curve-getPointAtDist ent d_end)) pt_end (if (> d_end d_start) (vlax-curve-getPointAtDist ent d_end) (vlax-curve-getPointAtDist ent d_start)) len (abs (- d_end d_start)) pt_mid (vlax-curve-getPointAtDist ent (+ (if (> d_end d_start) d_start d_end) (* len 0.5))) deriv (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtPoint ent pt_mid)) rtx (- (atan (cadr deriv) (car deriv)) (angle '(0 0 0) (getvar "UCSXDIR"))) OK (apply 'append (mapcar '(lambda (x) (mapcar '(lambda (zx) (equal (list (car x) (cadr x)) (list (car zx) (cadr zx)) 1E-04)) l_z)) (list pt_start pt_end))) ) (cond ((eq (length (vl-remove nil OK)) 2) (setq old-dim (getvar "DIMZIN")) (setvar "DIMZIN" 0) (setq arrow (if (> (vlax-curve-getParamAtPoint ent (cadr l_z)) (vlax-curve-getParamAtPoint ent (car l_z))) (if (member (apply 'min (mapcar 'caddr l_z)) (car l_z)) "<<<" ">>>") (if (member (apply 'min (mapcar 'caddr l_z)) (car l_z)) ">>>" "<<<") ) ) (setq arrow (if (or (> rtx (* pi 0.5)) (< rtx (- (* pi 0.5)))) (if (eq arrow ">>>") "<<<" ">>>") (if (eq arrow ">>>") ">>>" "<<<") ) ) (if (or (> rtx (* pi 0.5)) (< rtx (- (* pi 0.5)))) (setq rtx (+ rtx pi))) (setq nw_obj (vla-InsertBlock Space (vlax-3d-point pt_mid) "H-BLOCK" 1 1 1 rtx)) (vlax-put nw_obj 'Layer "H-Block") (mapcar '(lambda (x y) (vla-put-textstring x y) ) (vlax-safearray->list (vlax-variant-value (vla-getattributes nw_obj))) (list (strcat (rtos len 2 2) "m") arrow (strcat (rtos (* (/ (abs (apply '- (mapcar 'caddr l_z))) len) 100.0) 2 2) "%") ) ) (mapcar '(lambda (x y / nw_obj) (setq nw_obj (vla-addMtext Space (vlax-3d-point x) 0.0 y ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'Color) (list 5 0.79 5 x "Arial" "H-Elevation" (* pi 0.5) 4) ) ) (list (polar (car l_z) pi 0.79) (polar (cadr l_z) pi 0.79)) (list (rtos (caddar l_z) 2 2) (rtos (car (cddadr l_z)) 2 2)) ) (cond ((eq (vla-get-ObjectName vla_obj) "AcDbPolyline") (mapcar '(lambda (x) (if (not (eq (vlax-curve-getParamAtPoint ent x) (fix (vlax-curve-getParamAtPoint ent x)))) (add_vtx vla_obj (vlax-curve-getParamAtPoint ent x) ent) ) ) l_z ) (setq n (fix (apply 'min (mapcar '(lambda (x) (vlax-curve-getParamAtPoint ent x)) l_z)))) (repeat (1+ (fix (abs (apply '- (mapcar '(lambda (x) (vlax-curve-getParamAtPoint ent x)) l_z))))) (if (not (equal (vlax-curve-getPointAtParam ent n) (car l_pt) 1E-08)) (setq l_pt (cons (vlax-curve-getPointAtParam ent n) l_pt) l_blg (cons (vla-GetBulge vla_obj n) l_blg) ) ) (setq n (1+ n)) ) (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) (reverse l_pt))) ) n -1 ) (mapcar '(lambda (x) (vla-SetBulge nw_pl (setq n (1+ n)) x)) (reverse l_blg)) ) ((eq (vla-get-ObjectName vla_obj) "AcDbArc") (setq pt_cen (vlax-safearray->list (vlax-variant-value (vla-get-Center vla_obj)))) (setq nw_pl (vla-AddArc Space (vla-get-Center vla_obj) (vla-get-Radius vla_obj) (angle pt_cen pt_start) (angle pt_cen pt_end))) ) ((eq (vla-get-ObjectName vla_obj) "AcDbLine") (setq nw_pl (vla-AddLine Space (vlax-3d-point pt_start) (vlax-3d-point pt_end))) ) ) (vlax-put nw_pl 'Layer "H-Line") (vlax-put nw_pl 'Color 2) (setvar "DIMZIN" old-dim) ) (T (princ "\nInsufficient coincidence between curvilinear object and insertion") ) ) (vla-endundomark AcDoc) (prin1) ) Edited September 5 by macros55 Quote Link to comment Share on other sites More sharing options...
