Can anyone help me? get the attribute value based on the block name
3 hours ago, Kvlar said:
i get an error like this:
error: bad argument type: VLA-OBJECT <Entity name: 181bbe5aaf0>
Is there anything I did wrong?
But, thank you for helping me
No just me coding in notepad and not testing the code. needed to converted the nentsel to vla-object updated the  code.
Edited by mhupp
I tried testing the code, but the block name I got was random like *U414 or *U180 . Not the original block name.
Correct me if I'm wrong
Here, try this mhupp's mod...
;; PULL BLOCKS NAME TO UPDATE ATTRIBUTE
(defun C:ATTBLKNAME () (C:ABN))
(defun C:ABN ( / effectivename ent Name Att )
  (defun effectivename ( ent / blk rep )
    (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
      (if
        (and
          (setq rep
            (cdadr
              (assoc -3
                (entget
                  (cdr
                    (assoc 330
                      (entget
                        (tblobjname "block" blk)
                 '("AcDbBlockRepBTag")
          (setq rep (handent (cdr (assoc 1005 rep))))
        (setq blk (cdr (assoc 2 (entget rep))))
    blk
  (while (setq ent (car (entsel "\nSelect Block"))) ;gets an entity name using while will keep repeating if you keep selecting an entity
    (if (= (cdr (assoc 0 (entget ent))) "INSERT") ;test if its a block
        (setq Name (effectivename ent)) ; pulls the name
        (setq Att (vlax-ename->vla-object (car (nentsel "Select Attribute Text to update")))) ; nentsel can get entity names inisde blocks
        (vla-put-textstring Att Name) ;update entity with name
      (progn ;if entity isn't a block will prompt user
        (prompt "\nNot a Block Pick again")
        (c:ABN) ;and start the comman over again.
  • Like 2
this is exactly what I need.
Thank you very much to all of you guys 🙏
I hope I can be an expert in making autolisp like all of you
