EYNLLIB Posted May 17 Share Posted May 17 I'm almost there with my workflow, but I need a little help to get it just right. Here's what I'm trying to do: Type command Select block Pick Mleader arrow location Pick Mleader landing location Mleader content should automatically populate with the "SW_LENGTH" parameter from the block Everything works great up until step 5. After I pick both Mleader points, the Mleader text box opens for me to fill out (it's blank). But if I click in the drawing area, it exits the text box and fills in the correct info. So, how do I skip that last step and have the Mleader content fill in automatically without Autocad opening the text edit box? ;; Get Dynamic Block Property Value - Lee Mac ;; Returns the value of a Dynamic Block property (if present) ;; blk - [vla] VLA Dynamic Block Reference object ;; prp - [str] Dynamic Block property name (case-insensitive) (defun LM:getdynpropvalue (blk prp) (setq prp (strcase prp)) (vl-some '(lambda (x) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'Value))) (vlax-invoke blk 'GetDynamicBlockProperties))) (defun c:swtest () (setq blockName (car (entsel "\nSelect Block: "))) (if (and blockName (eq (cdr (assoc 0 (entget blockName))) "INSERT")) (progn (setq vlaBlock (vlax-ename->vla-object blockName)) (setq SW_LENGTH (LM:getdynpropvalue vlaBlock "SW_LENGTH")) (if SW_LENGTH (progn (setq textString (strcat "SW_LENGTH: " (rtos SW_LENGTH 2 2))) (princ (strcat "\n" textString)) (if (setq ins (getpoint "\nSpecify start point for MLeader: ")) (progn (setq endPoint (getpoint "\nSpecify end point for MLeader: " ins)) (setq curlay (getvar "CLAYER")) (setvar 'CMDECHO 0) (command "_.undo" "_group") (setvar 'CLAYER "S - TEXT") (command "CMLEADERSTYLE" "NORMAL - SW") (setvar 'CMDECHO 1) (initcommandversion) (command ".MLeader" ins endPoint "") (while (> (getvar "CMDACTIVE") 0) (command PAUSE)) (setq mleaderObj (vlax-ename->vla-object (entlast))) (vla-put-TextString mleaderObj textString) (setvar 'CMDECHO 0) (command "CMLEADERSTYLE" "Normal") (command "_.LAYER" "_SET" curlay "") (command "_.undo" "_end") (setvar 'CMDECHO 1) (princ "MLeader with SW_LENGTH created.")) (alert "Insertion point not specified!"))) (alert "SW_LENGTH attribute not found!"))) (alert "Selected entity is not a block!")) (princ)) Quote Link to comment Share on other sites More sharing options...
EYNLLIB Posted May 17 Author Share Posted May 17 For reference, I have a similar routine that grabs the length of a polyline and appends the mleader content with some custom text and the length that works perfectly; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; CUSTOM FUNCTIONS ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun my-mod (x y) (- x (* y (fix (/ x y)))) ) (defun dot-product (vec1 vec2) (+ (* (nth 0 vec1) (nth 0 vec2)) (* (nth 1 vec1) (nth 1 vec2))) ) (defun list->points (lst / result x y) (setq result '()) (while lst (setq x (car lst) y (cadr lst) lst (cddr lst)) (setq result (append result (list (list x y)))) ) result ) (defun distance (pt1 pt2) (sqrt (+ (expt (- (car pt2) (car pt1)) 2) (expt (- (cadr pt2) (cadr pt1)) 2))) ) (defun distance-to-segment (p a b) (setq l2 (distance a b)) (if (= l2 0.0) (distance p a) (progn (setq denominator (dot-product (mapcar '- b a) (mapcar '- p a))) (setq temp (/ denominator (dot-product (mapcar '- b a) (mapcar '- b a)))) (setq projection (mapcar '+ a (mapcar '* (mapcar '- b a) (list temp temp temp)))) (distance p projection) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; END CUSTOM FUNCTIONS ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN PROGRAM ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:sw () (initget 1 "1 2 3 4 5") (setq userNumber (getint "\nEnter Shearwal Type (1-5): ")) (if userNumber (progn (setq selectedEntity (entsel "\nSelect a polyline: ")) (if (or (null selectedEntity) (/= "LWPOLYLINE" (cdr (assoc 0 (entget (car selectedEntity)))))) (progn (princ "\nCancelled or not a polyline.") (exit) ) ) (setq pickedPoint (cadr selectedEntity)) (setq polyline (vlax-ename->vla-object (car selectedEntity))) (setq vertices (vlax-get polyline 'Coordinates)) (setq vertices (list->points vertices)) (setq numVertices (length vertices)) (setq closestSegment nil) (setq i 0) (while (< i numVertices) (setq pt1 (nth i vertices)) (setq pt2 (nth (my-mod (+ i 1) numVertices) vertices)) (setq distToSegment (distance-to-segment pickedPoint pt1 pt2)) (if (or (null closestSegment) (< distToSegment (car closestSegment))) (setq closestSegment (cons distToSegment (list pt1 pt2))) ) (setq i (+ i 1)) ) (setq segmentlength (distance (nth 0 (cdr closestSegment)) (nth 1 (cdr closestSegment)))) (setq roundedLength (fix (+ 0.5 segmentlength))) (setq feet (fix (/ roundedLength 12))) (setq inches (rem roundedLength 12)) (setq str (strcat "SW" (itoa userNumber) " (" (itoa feet) "'-" (itoa inches) "\")")) (if (setq ins (getpoint "\nSpecify start point for mleader: ")) (progn (setq endPoint (getpoint "\nSpecify end point for mleader: " ins)) (setq curlay (getvar "CLAYER")) (setvar 'CMDECHO 0) (setvar 'CLAYER "S - TEXT") (command "cmleaderstyle" "Normal - SW") (setvar 'CMDECHO 1) (setq mleaderObj (vlax-invoke (vlax-get (vla-get-ActiveDocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace ) ) 'AddMLeader (append ins endPoint) 0 ) ) (vla-put-TextString mleaderObj str) (setvar 'CMDECHO 0) (command "REGEN") (setvar 'CLAYER curlay) (command "cmleaderstyle" "Normal") (setvar 'CMDECHO 1) ) ) ) ) (princ (strcat "\nExact Length of Shearwall: " (rtos segmentlength))) ; Print the shearwall length (princ) ) Quote Link to comment Share on other sites More sharing options...
EYNLLIB Posted May 17 Author Share Posted May 17 as an update, i fixed the code using VLAX-INVOKE method to create the mleader: it's friday...give me a break (defun LM:getdynpropvalue (blk prp) (setq prp (strcase prp)) (vl-some '(lambda (x) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'Value))) (vlax-invoke blk 'GetDynamicBlockProperties))) (defun c:swtest () (setq blockName (car (entsel "\nSelect Block: "))) (if (and blockName (eq (cdr (assoc 0 (entget blockName))) "INSERT")) (progn (setq vlaBlock (vlax-ename->vla-object blockName)) (setq SW_LENGTH (LM:getdynpropvalue vlaBlock "SW_LENGTH")) (if SW_LENGTH (progn (setq textString (strcat "SW_LENGTH: " (rtos SW_LENGTH 2 2))) (princ (strcat "\n" textString)) (if (setq ins (getpoint "\nSpecify start point for MLeader: ")) (progn (setq endPoint (getpoint "\nSpecify end point for MLeader: " ins)) (setq curlay (getvar "CLAYER")) (setvar 'CMDECHO 0) (command "_.undo" "_group") (setvar 'CLAYER "S - TEXT") (command "CMLEADERSTYLE" "NORMAL - SW") (setvar 'CMDECHO 1) (initcommandversion) ;; Creating MLeader using vlax-invoke method (setq mleaderObj (vlax-invoke (vlax-get (vla-get-ActiveDocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace)) 'AddMLeader (append ins endPoint) 0)) (vla-put-TextString mleaderObj textString) (setvar 'CMDECHO 0) (command "CMLEADERSTYLE" "Normal") (command "_.LAYER" "_SET" curlay "") (command "_.undo" "_end") (setvar 'CMDECHO 1) (princ "MLeader with SW_LENGTH created.")) (alert "Insertion point not specified!"))) (alert "SW_LENGTH attribute not found!"))) (alert "Selected entity is not a block!")) (princ)) 1 Quote Link to comment Share on other sites More sharing options...
