update lisp coordenates X,Y (format)
leo321
now
N=7490570.926
E=   687539.212
change need
N=7.490.570,926
E=   687.539,212
(defun C:LP(/ PNT1 P1X P1Y STDY DY COORDN COORDE PTXT)
    (setq PNT1 (getpoint
      "\nPick coordinate point: "))
    (setq P1X (car pnt1)) ;x coord
    (setq P1Y (cadr pnt1)) ;y coord
    (setq STDX (rtos P1X 2 3))
    (setq STDY (rtos P1Y 2 3))
    (setq COORDN (strcat "N=" STDY  ))
    (setq COORDE (strcat "E=   " STDX  ))
    (setq PTXT (getpoint
      "\nPick text location: "))
    (command "LEADER" PNT1 PTXT "" COORDN  COORDE "")
My way
(defun convert_str2mil (str2cnv flag / l_str n l_nw)
	(setq l_str (if flag (reverse (vl-string->list str2cnv)) (vl-string->list str2cnv)) n 1)
	(while l_str
		(if (zerop (rem n 3))
			(setq l_nw (cons 46 (cons (car l_str) l_nw)))
			(setq l_nw (cons (car l_str) l_nw))
		(setq l_str (cdr l_str) n (1+ n))
	(vl-list->string (if (not flag) (reverse l_nw) l_nw))
(defun C:LP ( / PNT1 P1X P1Y STDX STDY PTXT mantisse p_decimal)
    (setq STDX
      (strcat
        (convert_str2mil (rtos (setq mantisse (fix P1X)) 2 0) T)
        (substr (convert_str2mil (substr (rtos (setq p_decimal (- P1X (fix P1X))) 2) 3) nil) 1 3)
    (setq STDY
      (strcat
        (convert_str2mil (rtos (setq mantisse (fix P1Y)) 2 0) T)
        (substr (convert_str2mil (substr (rtos (setq p_decimal (- P1Y (fix P1Y))) 2) 3) nil) 1 3)
    (if (eq (substr STDX 1 1) ".") (setq STDX (substr STDX 2)))
    (if (eq (substr STDY 1 1) ".") (setq STDY (substr STDY 2)))
    (command "_.LEADER" PNT1 PTXT "" (strcat "N=" STDY  "\nE=   " STDX "") "")
