duke Posted May 16, 2024 Posted May 16, 2024 Hello again friends ‼‼ I have a doubt if it is possible to touch a POLY and somehow capture the coordinates of the 2 vertices that make up the segment where I touched the POLY. I don't know if I explain myself. I am attaching an image for greater understanding. And thank you very much in advance ‼‼‼‼‼ Quote
Jonathan Handojo Posted May 16, 2024 Posted May 16, 2024 Yes, it's possible: (defun c:foo ( / pl pm) (and (setq pl (entsel "\nSelect polyline <exit>: ")) (progn (setq pm (vlax-curve-getParamAtPoint (car pl) (vlax-curve-getClosestPointTo (car pl) (trans (cadr pl) 1 0)))) (princ (list (vlax-curve-getpointatparam (car pl) (fix pm)) (vlax-curve-getpointatparam (car pl) (1+ (fix pm))) ) ) ) ) (princ) ) 2 Quote
duke Posted May 16, 2024 Author Posted May 16, 2024 1 hour ago, Jonathan Handojo said: Yes, it's possible: (defun c:foo ( / pl pm) (and (setq pl (entsel "\nSelect polyline <exit>: ")) (progn (setq pm (vlax-curve-getParamAtPoint (car pl) (vlax-curve-getClosestPointTo (car pl) (trans (cadr pl) 1 0)))) (princ (list (vlax-curve-getpointatparam (car pl) (fix pm)) (vlax-curve-getpointatparam (car pl) (1+ (fix pm))) ) ) ) ) (princ) ) Bro,, you save meeeee ‼‼‼‼‼ THANKS ‼‼‼‼‼ Quote
