Sharper Posted May 23, 2024 Posted May 23, 2024 1. I will go through some files tomorrow and see what else appears on these lines, I don't think it's a lot. 2. Yes the Qualify(1.000,0.0,0.0) will always be the same and will always change to Qualify(1.000,0.0,0.035) 3. Could you do it similar to the code you made for MrBojangles, but i'd only need to pass the 1st part for filename as this will change from job to job, the other 2 will be set as shown in 2. 4. They're not coordinates (although they do look similar, they're tool setup data for the cnc machine, so they will always be as shown. In this case Qualify is the name for the operation type, the first part of numbers"1.000,0" is the safe position above the part for the tool, the next part "0,0" is for any offset above the part to leave any excess material if that's required (not in my case), and the last part "0,0" is an offset to the side of the part, again to leave some excess material (this i what i do want and the amount is always the same. I understand your questions, and i'll answer as many as you have or need. I never thought autolisp could do this until i saw this Topic today Quote
pkenewell Posted May 23, 2024 Posted May 23, 2024 2 minutes ago, Sharper said: 1. I will go through some files tomorrow and see what else appears on these lines, I don't think it's a lot. 2. Yes the Qualify(1.000,0.0,0.0) will always be the same and will always change to Qualify(1.000,0.0,0.035) 3. Could you do it similar to the code you made for MrBojangles, but i'd only need to pass the 1st part for filename as this will change from job to job, the other 2 will be set as shown in 2. 4. They're not coordinates (although they do look similar, they're tool setup data for the cnc machine, so they will always be as shown. In this case Qualify is the name for the operation type, the first part of numbers"1.000,0" is the safe position above the part for the tool, the next part "0,0" is for any offset above the part to leave any excess material if that's required (not in my case), and the last part "0,0" is an offset to the side of the part, again to leave some excess material (this i what i do want and the amount is always the same. I understand your questions, and i'll answer as many as you have or need. I never thought autolisp could do this until i saw this Topic today @Sharper Ok thanks for the answers. It should not be too much effort to write this for you. Just to let you know however, I'll be out of communication for the next 5 or 6 days since I'll be on Holiday. I will get on this afterwards. If I get any time tonight I might get to it sooner, but I'll be traveling tomorrow morning. 1 Quote
Sharper Posted May 23, 2024 Posted May 23, 2024 My friend there is no rush. i've been doing this manually for years lol. I break up from work tomorrow evening for a week also. Have safe travels. 1 Quote
pkenewell Posted May 23, 2024 Posted May 23, 2024 2 minutes ago, Sharper said: I break up from work tomorrow evening for a week also. Have safe travels. You as Well! 1 Quote
Sharper Posted May 30, 2024 Posted May 30, 2024 I've looked through a few hundred files There seems to be only 2 variants, and they're as follows Qualify(1.000,0.0,0.0) ; Qualify Tool LP Qualify(1.000,0.0,0.0) ; Qualify Offsets Quote
pkenewell Posted May 30, 2024 Posted May 30, 2024 (edited) @Sharper Hi - I've been on Holiday but didn't forget you , Please give this code a try. I minimally tested it with the example code you posted and it worked. Alter the path and file extension to suit you needs in the UPDATEGC command. Just in case - I recommend you backup your Gcode file before using. ;; Escape Wildcards - Lee Mac ;; Escapes wildcard special characters in a supplied string (defun LM:escapewildcards ( str ) (if (wcmatch str "*[-#@.*?~`[`,]*,*`]*") (if (wcmatch str "[-#@.*?~`[`,]*,`]*") (strcat "`" (substr str 1 1) (LM:escapewildcards (substr str 2))) (strcat (substr str 1 1) (LM:escapewildcards (substr str 2))) ) str ) ) (defun ReplaceCodes (file kw1 kw2 / flg fp ln ls n) (if (and file (setq file (findfile file))) (progn (setq fp (open file "r") flg nil) (while (setq ln (read-line fp)) (if (wcmatch ln (strcat "*" (LM:escapewildcards kw1) "*")) (setq ln (vl-string-subst kw2 kw1 ln) ls (cons ln ls) flg T ) (setq ls (cons ln ls)) ) ) (close fp) (if (and ls flg) (progn (setq fp (open file "w") ls (reverse ls) n 0 ) (repeat (length ls) (write-line (nth n ls) fp) (setq n (1+ n)) ) (close fp) (princ "\nFile Updated.") ) (princ "\nNo lines found in file that match the pattern. ") ) ) (princ "\nFile Not found.") ) (princ) ) (defun c:UpdateGC () (if (setq fil (getfiled "Select Gcode File to Update" "C:\\Myfolder\\" "gco" 4)) (ReplaceCodes fil "Qualify(1.000,0.0,0.0)" "Qualify(1.000,0.0,0.035)") ) ) Thanks to Lee Mac for the "Escape Wildcards" code. Edited May 30, 2024 by pkenewell 1 Quote
Sharper Posted May 30, 2024 Posted May 30, 2024 Hey pkenewell, I'm still on holiday myself, I had some spare time due to weather so looked through some files. I wasn't expecting you to do anything whilst your away , but seeing as you have lol i will indeed give it a go when I get back tomorrow 1 Quote
pkenewell Posted May 30, 2024 Posted May 30, 2024 1 hour ago, Sharper said: Hey pkenewell, I'm still on holiday myself, I had some spare time due to weather so looked through some files. I wasn't expecting you to do anything whilst your away , but seeing as you have lol i will indeed give it a go when I get back tomorrow @Sharper Actually I'm back from Holiday now so no problem . Hope your Holiday is going well. Just let me know how it works when you have time to look at it. 1 1 Quote
Sharper Posted May 31, 2024 Posted May 31, 2024 @pkenewellThis works perfectly. I can usually see how the programs work, but this work of genius, i can't get my head around... I have a couple of projects coming up where this would be used around 10 times each. Thank you my friend 2 Quote
Mr Bojangles Posted May 31, 2024 Author Posted May 31, 2024 16 hours ago, pkenewell said: @Sharper Hi - I've been on Holiday but didn't forget you , Please give this code a try. I minimally tested it with the example code you posted and it worked. Alter the path and file extension to suit you needs in the UPDATEGC command. Just in case - I recommend you backup your Gcode file before using. ;; Escape Wildcards - Lee Mac ;; Escapes wildcard special characters in a supplied string (defun LM:escapewildcards ( str ) (if (wcmatch str "*[-#@.*?~`[`,]*,*`]*") (if (wcmatch str "[-#@.*?~`[`,]*,`]*") (strcat "`" (substr str 1 1) (LM:escapewildcards (substr str 2))) (strcat (substr str 1 1) (LM:escapewildcards (substr str 2))) ) str ) ) (defun ReplaceCodes (file kw1 kw2 / flg fp ln ls n) (if (and file (setq file (findfile file))) (progn (setq fp (open file "r") flg nil) (while (setq ln (read-line fp)) (if (wcmatch ln (strcat "*" (LM:escapewildcards kw1) "*")) (setq ln (vl-string-subst kw2 kw1 ln) ls (cons ln ls) flg T ) (setq ls (cons ln ls)) ) ) (close fp) (if (and ls flg) (progn (setq fp (open file "w") ls (reverse ls) n 0 ) (repeat (length ls) (write-line (nth n ls) fp) (setq n (1+ n)) ) (close fp) (princ "\nFile Updated.") ) (princ "\nNo lines found in file that match the pattern. ") ) ) (princ "\nFile Not found.") ) (princ) ) (defun c:UpdateGC () (if (setq fil (getfiled "Select Gcode File to Update" "C:\\Myfolder\\" "gco" 4)) (ReplaceCodes fil "Qualify(1.000,0.0,0.0)" "Qualify(1.000,0.0,0.035)") ) ) Thanks to Lee Mac for the "Escape Wildcards" code. I'll be honest, I didn't understand what you were asking for originally Now I see this lisp I understand, and it has the gears in my mind turning with possibilities haha Knew you were in good hands.. Have a great weekend both 1 1 Quote
