AutoCAD to generate only 1 layout for the drawing instead of 2. Problem setting up other users.
I have previously changed my settings/options to have AutoCAD only generate 1 layout instead of 2.  I can't remember how or where I did it at and I am coming up short searching the web for an answer as well.  Can someone help me get the setting/option so I can set up other users with this?
This is what my tabs look like when I open or create a new drawing.
All the  other users in my office also have a Layout2 tab.
My guess, after about 22 seconds of research, is to revise your template. Makes sense, that's your go-to setup.
Look at Options, Files, Template you probably have a different dwt set up as default, as suggested by CyberAngel.
